Cannot bind refkey to part edge in assembly
william
william
Hello All
I am having issues trying to bind a refkey to a part edge selected within the assembly context.
What I am trying to achieve is to store selection sets inside an assembly file by writing the refkeys and key context to custom iproperties. I can then query the election sets later to get information like total length of edges, etc.
Rule 1: Prompts to select part edges within an assembly, as each edge is selected it adds it to a string variable separated by comma's. Once the selection is complete, write the string variable to a custom iProperty where it can be retrieved later. Likewise for the key context.
Rule 2: Checks the custom iProperties to see if any selection sets exist, if yes then split the string variable by the comma's to get each individual refkey. Once I have the refkey I should be able to retrieve the object (edge) and get my length info, etc.
The problem I am having is getting the object from the refkey and key context. It keeps throwing an error on this line.
foundEdge = refKeyMgr.BindKeyToObject(edgeRefKey, refKeyContext)
I am a bit stuck on this.
I have used the same rules to do something similar for selecting sketch elements inside a part file (see: Rules for selection set of sketch lines and calculating the length. - Autodesk Community - Inventor) and that has worked fine, but it doesn't need the keycontext. I think this is where it is going wrong.
I have been referencing this post (https://modthemachine.typepad.com/my_weblog/2015/09/understanding-reference-keys-in-inventor.html).
Any help is appreciated.
Rule 1:
Sub Main()
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("This rule can only be run in an .iam environment" & vbNewLine & "The rule will exit...", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
' Get the active document.
Dim oDoc = ThisDoc.Document
' Set a reference to the ReferenceKeyManager object.
Dim refKeyMgr As ReferenceKeyManager = oDoc.ReferenceKeyManager
' Create a key context.
Dim keyContext As Long = refKeyMgr.CreateKeyContext
' Get the key context as an array of bytes and
' convert it to a string.
Dim contextArray() As Byte = New Byte() {}
refKeyMgr.SaveContextToArray(keyContext, contextArray)
Dim strContext As String
strContext = refKeyMgr.KeyToString(contextArray)
iProperties.Value("Custom", "RefKeyContext") = strContext
Dim SelectionSet As New ArrayList
oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
userParams = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
For Each oProp In oCustomPropertySet
	If oProp.name.Contains("RefKeys") Then
		SelectionSet.Add(oProp.name)
Next
SelectionSet.Add("Add new selection set")
SelectedParam = InputListBox("", SelectionSet, SelectionSet, Title := "Available Parameters", ListName := "Please select an Option")
If SelectedParam = "Add new selection set" Then
	myparam = InputBox("Enter the selection set name", "Title", "Test")
	iProperties.Value("Custom", myparam & "_RefKeys") = ""
	Try
		oParameter = userParams.AddByValue(myparam & "_Value", "", UnitsTypeEnum.kMillimeterLengthUnits)
	Catch
		'Parameter already exists
	End Try
	SelectionSet.Add(myparam & "_RefKeys")
	SelectedParam = myparam & "_RefKeys"
Dim oHSet As HighlightSet = oDoc.CreateHighlightSet()
oHSet.Color = ThisApplication.TransientObjects.CreateColor(185, 0, 0) 'Red
Start :
Dim oEdge As Edge
oEdge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select a edge to add to the combined measurement")
Dim refKey() As Byte = New Byte() {}
oEdge.GetReferenceKey(refKey, keyContext)
Dim strRefKey As String = refKeyMgr.KeyToString(refKey)
Dim strAccumulatedRefKey As String = strAccumulatedRefKey & "," & strRefKey
oHSet.AddItem(oEdge)
Q = MessageBox.Show("Select another edge?", "Create Selection Set", MessageBoxButtons.YesNo)
oDoc.SelectSet.Clear()
If Q = vbYes Then
	GoTo Start
iProperties.Value("Custom", SelectedParam) = strAccumulatedRefKey
oHSet.Clear()
End Sub
Rule 2:
'https://forums.autodesk.com/t5/inventor-programming-ilogic/out-of-memory-error-while-working-with-referencekey/td-p/10590755
'https://modthemachine.typepad.com/my_weblog/2015/09/understanding-reference-keys-in-inventor.html
Sub Main()
'On Error Resume Next
    Return
oContinue = False
	If oProp.name.Contains("RefKeyContext") Then
		oContinue = True
Next
If oContinue = False Then
	MessageBox.Show("This document is missing essential information to execute this rule. Please ensure the selection sets have been created and the RefKeyContext property exists." & vbNewLine & "The rule will exit...", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
' Get a reference to the reference key manager.
' Read the reference key strings from the file.
Dim context As String = iProperties.Value("Custom", "RefKeyContext")
' Convert the string to byte arrays.
refKeyMgr.StringToKey(context, contextArray)
' Create the context by loading the data.
Dim refKeyContext As Long
refKeyContext = refKeyMgr.LoadContextFromArray(contextArray)
Next
If SelectionSet.Count <= 0 Then
 Exit Sub
For i = 0 To SelectionSet.Count - 1
	ParameterName = SelectionSet(i).Replace("_RefKeys","")
	ParamExists = False
	Dim strRefKeysArray() As String =  iProperties.Value("Custom", SelectionSet(i)).Split(",")
	AccumulatedLength = 0
	For j = 1 To strRefKeysArray.Count - 1
		Dim strRefKey As String = strRefKeysArray(j)
	    Dim edgeRefKey() As Byte = New Byte() {}
	    refKeyMgr.StringToKey(strRefKey, edgeRefKey)
		Dim foundEdge As Edge
'		Dim oEdge As Edge
'		'oEdge = oDoc.SelectSet.Item(1)
'		oEdge = refKeyMgr.BindKeyToObject(edgeRefKey)
'		Dim oEval As CurveEvaluator = oEdge.Evaluator
'		Dim oMin, oMax, oLength As Double
'		oEval.GetParamExtents(oMin, oMax)
'		oEval.GetLengthAtParam(oMin, oMax, oLength)
'		If TypeOf foundObject Is Inventor.Edge Then
'			'MessageBox.Show("Message", "Title")
'		    Dim foundLine As Edge
'		    foundLine = refKeyMgr.BindKeyToObject(edgeRefKey)
'			Length = foundLine.Length
'		ElseIf TypeOf foundObject Is Inventor.SketchArc Then
'		    Dim foundArc As SketchArc
'		    foundArc = refKeyMgr.BindKeyToObject(edgeRefKey)
'			Length = foundArc.Length
'		Else
'			Length = 0
'		   	'Found object type is not supported
'		End If
		AccumulatedLength += oLength
	Next
		For Each oParam In userParams
			If oParam.Name.Contains(ParameterName & "_Value") Then
				ParamExists = True
				Parameter.Param(oParam.Name).Value = AccumulatedLength
		Next
	If ParamExists = False Then
		'MessageBox.Show("ParameterName: " & ParameterName, "Title")
		oParameter = userParams.AddByValue(ParameterName & "_Value", AccumulatedLength, UnitsTypeEnum.kMillimeterLengthUnits)
Next
RuleParametersOutput()
iLogicVb.UpdateWhenDone = True
End Sub
william
@YuhanZhang  You had some helpful posts in this thread (Solved: Out of memory error while working with ReferenceKey - Autodesk Community - Inventor) regarding the reference keys.
Can you see what I am doing wrong in the above rules?
This is the error I am getting on the below code. Line 70 (second rule)
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ReferenceKeyManager.BindKeyToObject(Byte[]& ReferenceKey, Int32 KeyContext, Object& MatchType)
at ThisRule.Main() in external rule: Estimating_Selection Set_Assembly Edges_Compute:line 70
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Michael.Navara
I'm sorry I don't test your code, but for this purpose you can use better approach using Attributes. RefKeys are very low level object which can be used, but in my opinion use attributes are more readable and flexible.
Sub Main()
StoreSelectSet()
PrintAvailableSelectSets()
QuerySelectSet()
End Sub
Private Sub StoreSelectSet()
	'Select set name
	Dim selectSetId = InputBox("SelectSet name (Cancel or empty value to skip)", "Store select set", "")
	If selectSetId = "" Then Return
	'Select set content
	Dim edgesList = New List(Of Edge)()
	Dim pick As Object
	Do
		pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select edge")
		Dim edge = TryCast(pick, Edge)
		If edge IsNot Nothing Then edgesList.Add(edge)
	Loop While pick IsNot Nothing
	'Store select set
	For Each edge As Edge In edgesList
		Dim attributeSet As AttributeSet
		Try
			attributeSet = Edge.AttributeSets("SelectSet")
		Catch ex As Exception
			attributeSet = Edge.AttributeSets.Add("SelectSet")
		End Try
		attributeSet.Add(selectSetId, ValueTypeEnum.kStringType, "")
	Next
End Sub
Private Sub PrintAvailableSelectSets()
	Dim attributeManager As AttributeManager = ThisDoc.Document.AttributeManager
	Dim attributesEnumerator As AttributesEnumerator = attributeManager.FindAttributes("SelectSet")
	Logger.Debug("Defined select sets")
	Dim sets = New List(Of String)
	For Each attribute As Inventor.Attribute In attributesEnumerator.OfType(Of Inventor.Attribute)
		Dim attName As String = Attribute.Name
		If sets.Contains(attName) Then Continue For
		Logger.Debug(attName)
		sets.Add(attName)
	Next
End Sub
Private Sub QuerySelectSet()
	'Select set name
	Dim selectSetId = InputBox("SelectSet name (Cancel or empty value to skip)", "Restore select set", "")
	'Restore select set
	Dim objectCollection As ObjectCollection = attributeManager.FindObjects("SelectSet", selectSetId)
	ThisDoc.Document.SelectSet.SelectMultiple(objectCollection)
End Sub
EDIT:
Sample how to obtain existing select sets added
EDIT 2:
Shorter version of PrintAvailableSelectSets method
    For Each attName In attributesEnumerator.OfType(Of Inventor.Attribute).Select(Function(att) att.Name).Distinct()
    Next
End Sub
william
Hello Michael
Thanks for the reply, it was helpful. I hadn't considered the use of Attribute sets.
Incidentally I discovered what was wrong with my original code to use rekeys. Since I haven't seen this issue publicized anywhere, I will note some points below.
The issue on the below line, was that I had the wrong Key Context.
In my first rule, I first created the key Context, and afterwards created the refkeys for the objects selected. As it turns out, the key context will change with each refkey retrieved. This means to get the correct key context I first need to retrieve the ref keys for the objects first, then create the key context.
That can be seen in the below code.
Sub Main ()
    Dim doc As Document = ThisApplication.ActiveDocument
    ' Have a face and edge selected.
    Dim selFace As Face = ThisApplication.CommandManager.Pick(kPartFaceFilter, "Select face.")
    Dim selEdge As Edge = ThisApplication.CommandManager.Pick(kPartEdgeFilter, "Select edge.")
    Dim refKeyMgr As ReferenceKeyManager = doc.ReferenceKeyManager
    keyContext = refKeyMgr.CreateKeyContext
     ' Get reference keys from the selected entities.
    Dim faceRefKey() As Byte = New Byte() {}
    Call selFace.GetReferenceKey(faceRefKey, keyContext)
    Call selEdge.GetReferenceKey(edgeRefKey, keyContext)
    Call refKeyMgr.SaveContextToArray(keyContext, contextArray)
    ' Convert the reference keys to strings to make saving it easier.
    Dim strFaceKey As String
    strFaceKey = doc.ReferenceKeyManager.KeyToString(faceRefKey)
    Dim strEdgeKey As String
    strEdgeKey = doc.ReferenceKeyManager.KeyToString(edgeRefKey)
    ' Save the results to a file.
	'____Create and write to a text file_________________
	oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
	oWrite.WriteLine(strContext)
	oWrite.WriteLine(strEdgeKey)
	oWrite.WriteLine(strFaceKey)
	oWrite.Close()
	'open the file
	ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
End Sub
Then you can bind the keys back to the objects using this code
Sub Main()
    Dim edgeKey As String
    Dim faceKey As String
	'____Open and read a text file_______________________
	oRead = System.IO.File.OpenText(ThisDoc.PathAndFileName(False) & ".txt")
	context = oRead.ReadLine()
    edgeKey = oRead.ReadLine()
    faceKey = oRead.ReadLine()
	oRead.Close()
    Call refKeyMgr.StringToKey(edgeKey, edgeRefKey)
    Call refKeyMgr.StringToKey(faceKey, faceRefKey)
    Call refKeyMgr.StringToKey(context, contextArray)
    ' Bind back the face and edge.
    Dim foundFace As Face = refKeyMgr.BindKeyToObject(faceRefKey, refKeyContext)
    Dim foundEdge As Edge = refKeyMgr.BindKeyToObject(edgeRefKey,refKeyContext)
    ' Highlight the found entities.
    doc.SelectSet.Clear
    doc.SelectSet.Select(foundFace)
    doc.SelectSet.Select(foundEdge)
End Sub
Ultimately this ended up being a quicker implementation into my original code than changing to attribute sets, but thanks for the tips.
william
Here are the modified rules to create the edge selection sets, then compute the accumulated lengths for the edges.
Create edge selection sets:
Sub Main()
    Return
Next
SelectedParam = SelectedParam.Replace("_RefKeys", "")
	Try
	Catch
	End Try
Start :
Dim oEdge As Edge
If Q = vbYes Then
	GoTo Start
' Get the key context as an array of bytes and convert it to a string.
iProperties.Value("Custom", SelectedParam & "_RefKeyContext") = strContext
iProperties.Value("Custom", SelectedParam & "_RefKeys") = strAccumulatedRefKey
oHSet.Clear()
End Sub
Compute accumulated edge lengths.
Sub Main()
    Return
Next
 Exit Sub
	ParamExists = False
	Try
		context = iProperties.Value("Custom", ParameterName & "_RefKeyContext")
	Catch
    	Return
	End Try
		Try
		Catch
			MessageBox.Show("Error getting the edge object from the refkey, the rule will exit")
			Return
		End Try
		Try
			Dim oEval As CurveEvaluator = foundEdge.Evaluator
		Catch
			MessageBox.Show("There was an error getting the length from the edge object. It will be skipped and not added to the accumulated total length. Please check your inputs/select set")
		End Try
	Next
				ParamExists = True
		Next
Next
End Sub
