Cancel a command
Cancel a command
Cancel a command
I want to cancel every edit command when a inventor document is read-only and give the user a message. (such as ESC) The message i get but the command isn't cancelled. (wrong commandname "FDTrasparentCancel" ?)
How can I do this?
Code:
Private Sub mobjUserInputEvents_OnActivateCommand(ByVal CommandName As String, ByVal Context As NameValueMap)
On Error GoTo Errorhandler
Dim fs As New FileSystemObject
Dim oFile
Dim oINVDoc As Inventor.Document
Set oINVDoc = objInventorApp.ActiveDocument
If UCase(Left(oINVDoc.FullDocumentName, 3)) = "T:\" Then
'check of is file read_Only
Set oFile = fs.GetFile(oINVDoc.FullDocumentName)
If oFile.Attributes = 1 Or oFile.Attributes = 33 Then
objInventorApp.CommandManager.PromptMessage "Let op Command: " & oINVDoc.DisplayName & " is Read_Only en kan niet gewijzigd worden!", vbExclamation
'Cancel edit command
Dim oControlDef As ControlDefinition
Set oControlDef = objInventorApp.CommandManager.ControlDefinitions.Item("FDTrasparentCancel")
oControlDef.Execute
Exit Sub
Errorhandler:
GeneralErrorHandler "mobjUserInputEvents_OnActivateCommand"
End Sub
I just found how to cancel every command
objInventorApp.CommandManager.StopActiveCommand
but I want only to stop the edit commands.
Is that possible?
I just made a workaround to cancel the invoked command.
I hope there is a better (easier) way, so if anyone has a idea?
Now I've just one little problem with my code (see below)
When the command is cancelled the button in the panelbar stays pressed and my cursor has a plus sign to it.
I assume that the command isn't cancelled completly?
How can i make that the buttons aren't pressed? See attachment.
Code: This is a snippset of my previous code mobjUserInputEvents_OnActivateCommand
'close command
Dim oCancelCommand As clsCancelCommand
Set oCancelCommand = New clsCancelCommand
oCancelCommand.Initialize
oCancelCommand.SetTrigger
Set oCancelCommand = Nothing
Code in class -> clsCancelCommand
Option Explicit
Private WithEvents oInteractionEvents As InteractionEvents
Public Sub Initialize()
Set oInteractionEvents = objInventorApp.CommandManager.CreateInteractionEvents
oInteractionEvents.Start
Exit Sub
Errorhandler:
GeneralErrorHandler "Initialize-CancelCommand"
End Sub
Public Function SetTrigger() As Boolean
Dim strCommandName As String
On Error Resume Next
Do While LCase(strCommandName) = "interactionevents" Or strCommandName = ""
DoEvents
Loop
'Stop event
oInteractionEvents.Stop
End Function
Private Sub oInteractionEvents_OnTerminate()
'sluit active commando af
'Refresh panelbar!
End Sub
maxim.teleguz
add the following to your code:
System.Windows.Forms.SendKeys.SendWait("{ESC}")
ThisApplication.UserInterfaceManager.DoEvents
WCrihfield
Actually, that might not work if the proper window/dialog does not have top system focus at that moment.  Using SendKeys can be tricky.  You could try adding something like AppActivate(ThisApplication.Caption) on the line above the SendKeys line, but no guarantees.  A better option might be to execute one of Inventor's built-in commands for exiting out of an active dialog/command.  Something like "AppContextual_CancelCmd".  There are other more specific commands for canceling out of other more specific actions/commands, but that is about the most generic one.
To use it, the line of code would look similar to this:
ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_CancelCmd").Execute
Wesley Crihfield
(Not an Autodesk Employee)
maxim.teleguz
AppContextual_ApplyCmd                        Apply
AppContextual_BackCmd                        &Back
AppContextual_CancelCmd                        Cancel (ESC)
AppContextual_ContinueCmd                        &Continue
AppContextual_CreateCmd                        &Create
AppContextual_DoneCmd                        &Done [ESC]
AppContextual_OKCmd                        OK (Enter)
AppContextual_RemoveCmd                        &Remove
AppContextual_RestartCmd                        &Restart
AppContinueCmd                        Continue to next step
AppExitCmd                        Quit the application; prompts to save documents
FeaExResultsCmd                        Exit Results
HSL:Cable:End_Command                        Create current segment and exit the command
Archon:Done                        End current command
DragAndDrop.Popup.CancelCommand                        End the command without applying changes
DragAndDrop.Popup.EndCommand                        Complete the command and commit changes
AppCGUCS_CreateCmd
AppCGUCS_DoneCmd
AppCGUCS_RestartCmd
AppCleanScreenCmd
AppCloseAllCmd                        Close all the documents
AppNavigationBarCloseCmd
