Can you auto generate an assembly?
ben.jakeman
ben.jakeman
I am relatively new to Inventor and I am incredibly curious about its possibilities.
Can I write ILogic to create an assembly, prompt a user for X number of components, then place components correlating to X, and finally constraining them to a specified template? With the things I've seen since I've started using Inventor it seems like this is a possibility. Is Inventor that powerful?
Thank you!
bhavik4244
@ben.jakeman
yes it's possible to do. however, you have to explicitely define your sequence of actions.
    Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
    Dim doc As Document = ThisDoc.Document
    Dim ass As AssemblyDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
    ass.ComponentDefinition.Occurrences.Add(doc.FullFileName, oTg.CreateMatrix())
above is to add new assembly, simillarly you may add code to add componetns and constrain with Transient vector positions.
Bhavik Suthar
