Can we access textbox objects on the sheet object?
J_Pfeifer_
J_Pfeifer_
Having trouble, I want to replicate the ability to create a textbox on the drawing sheet itself. Not a sketch object on the sheet. I'm not seeing anything like Sheet.Textboxes?
What am I missing?
J_Pfeifer_
Just kidding I found it, 🙂 the object itself should refer to a sheet or sketch. Presumably I can just access or target this.
J_Pfeifer_
Ok I had thought I had found it, but playing around with different objects. You can add a textbox directly to the sheet through the sheets drawing notes. See below -
Sub main
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim OTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oSheet As Sheet = oDoc.Sheets(4)
	Dim InputText As String = "Testing textboxes"
	Dim TextPoint As Point2d = OTG.CreatePoint2d(5, 5)
	Dim iNote As DrawingNote = oSheet.DrawingNotes.GeneralNotes.AddFitted(TextPoint, InputText)
End Sub
The GeneralNotes has two different options identical to how we would create textboxes in other areas. Add fitted and Add by rectangle.
