Can VBA read text from a titleblock
Is it possible to have VBA read a plain text (not a property) string (in this case "TBVersion - 2") and put that into a custom property, bearing in mind that "TBVersion - 2" will increment ("TBVersion - 2.1", "TBVersion - 2.2", "TBVersion - 3" etc). If so, How?
Cheers
MattH
OK, lets make things a tad clearer, I want a version number somewhere in my titleblock (not in the template) which can then be read and written as a custom property by VBA once the titleblock is inserted into an IDW. In this way, I can tell if an IDW contains the latest titleblock or not.
Regards
MattH
Hello, Forgive me for questioning your workflow, however, if you were to create a custom property, do you then need to have this displayed on the drawing if the only way you utilize this is for question via a VBA routine? Either way, stash user defined properties here, Document.PropertySets.Item("User Defined Properties")Add(Value, PropertyName, PropertyID), that statement will add a custom property, doesn't allow you to specify the variable type though. HTH Scott
Thanks for the response, unfortunately this method has no link between the titleblock (and its version) and the custom property. (Funny enough its exactly how I currently do it!) If the titleblock is changed, the custom property has to be manually changed, I'm looking for a way to automate the process, thus allowing for accurate TB version number recording.
Cheers
MattH
