Can the built-in command be customize?
Hi! I am wondering whether it can be done or not? My requirement is that whenever a built-in command of Inventor is run(e.g. Creating a new sketch), some task should be performed automatically either before executing the command or after executing the command. Is it possible to do? If I am not wrong when I ware working with Inventor API in Inventor 4. All the commands were accessible by command ID and in that case the customization of the built-in command was possible. But what about in Inventor 7.0. If possible then how?
Yes you can monitor for commands and then perform some action based on those
commands. I did this once but don;t know if I still have the code. I'll
check. This will also probably be moved to the customization NG.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"manoj_vest" wrote in message
news:[email protected]...
then how?
Hi Dotson,
Sorry for being too late. ould you provide me some sample code.
Thanks in Advance
Search under User Interaction in the online programming help.
Sean Dotson, PE
> Hi Dotson,
> Thanks in Advance
