Can't set location for windows form control with .location. Please Help
I am trying to create a windows form within iLogic. Everything works except the lines defining the location on the controls. I keep getting the following error: 'New' cannot be used on an interface. The error refers to lines in the code that try to set the control location on the form. (i.e. "button1.Location = New Point(10,10)") Ihave pasted the code below and have it attached as well. I am in Inventor 2013.
AddReference ("C:\Windows\Microsoft.NET\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll")
Dim oOccurrence As ComponentOccurrence
Try
  oOccurrence = ThisDoc.Document.SelectSet.Item(1)
Catch
  MessageBox.Show("Please select a component before running this rule.", "iLogic")
  Return
End Try
Dim doc As Document
Dim PName As String
Dim PNum As String
'set the selected item
oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1)
PName = oOccurrence.Name
PNum = iProperties.Value(PName, "Custom", "Example_Property")
InputBox("Prompt", "Title",iProperties.Value(PName, "Custom", "Example_Property"))
    ' Create a new instance of the form.
    Dim form1 As New Form()
    ' Create two buttons to use as the accept and cancel buttons.
    Dim button1 As New System.windows.forms.Button()
	Dim button2 As New System.windows.forms.Button()
    Dim TextBox1 As New System.windows.forms.textbox()
    ' Set the text of button1 to "OK".
    button1.Text = "OK"
    ' Set the position of the button on the form.
    ' Set the text of button2 to "Cancel".
    button2.Text = "Cancel"
    ' Set the position of the button based on the location of button1
    button2.Location = New Point(button1.Left, button1.Height + button1.Top + 10)
	' Set the text of TextBox1 to "Default".
	TextBox1.Text = PNum
    ' Set the position of the button based on the location of button2
    TextBox1.Location = New Point(button1.Left, button2.Height + button1.Top + 10)
    ' Set the caption bar text of the form.
    form1.Text = "My Dialog Box"
    ' Display a help button on the form.
    form1.HelpButton = True
    ' Define the border style of the form to a dialog box.
    form1.FormBorderStyle = FormBorderStyle.FixedDialog
    ' Set the MaximizeBox to false to remove the maximize box.
    form1.MaximizeBox = False
    ' Set the MinimizeBox to false to remove the minimize box.
    form1.MinimizeBox = False
    ' Set the accept button of the form to button1.
    form1.AcceptButton = button1
    ' Set the cancel button of the form to button2.
    form1.CancelButton = button2
    ' Set the start position of the form to the center of the screen.
    form1.StartPosition = FormStartPosition.CenterScreen
    ' Add button1 to the form.
    form1.Controls.Add(button1)
    ' Add button2 to the form.
    form1.Controls.Add(button2)
    ' Add textBox1 to the form.
    form1.Controls.Add(TextBox1)
    ' Display the form as a modal dialog box.
    form1.ShowDialog()
MessageBox.Show(TextBox1.text, Textbox1.text)
 Thanks for lookng,
Thomas Ruscher
philippe.leefsma
Hi Thomas,
Might be the wrong "Point" class. Did you try "System.Drawing.Point" instead?
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
