Can't obtain Sheet object in Apprentice 2011 in VB6 app
According to Intellisense the Sheets collection has an Item method but when I execute this code it say the object does not support this method.  Also, notice how "item" is in lowercase.  I type upper case but as soon as I move the cursor to another line it reverts back to lower case, why?  I can get the Count property of Sheets but not Item, why?
Dim oApprenticeServerDrawingDocument As ApprenticeServerDrawingDocument
Dim oSheet As Sheet
Set oSheet = oApprenticeServerDrawingDocument.Sheets.item(1)
Mike.Wohletz
I am not getting that problem in .NET as the following works fine,
    Dim oASCApp As ApprenticeServerComponent = New ApprenticeServerComponent
        Dim oASDDoc As ApprenticeServerDrawingDocument = oASCApp.Open("c:\001245.idw")
        Dim oSheet As Sheet
        oSheet = oASDDoc.Sheets.Item(1)
        MsgBox(oSheet.Name)
        oASDDoc.Close()
        oASCApp = Nothing
Actually I'm wrong, the code is dying on Set oTB = oSheet.TitleBlock
The error message says "Object does not support this action".
                        Debug.Print oApprenticeServerDrawingDocument.Sheets.item(1).Name
                        Debug.Print oApprenticeServerDrawingDocument.Sheets.Count
                        Dim oTB As inventor.TitleBlock
Mike.Wohletz
I don't think that ApprenticeServer supports anything as deep as the titleBlock..
I know Apprentice is mostly read-only but I thought it otherwise has complete access.  Can someone from Autodesk please comment on this.
