Can't create a simple hole on a face of a simple part
gak19043
Message 1 of 8
gak19043
I am trying to simply place a hole onto a face of a part. Even though Inventor Help says I can, there is no option or prompt to select a face. It says, "valid inputs for holes include a face...."
My "Allow center point creation is ON" because it says that when it is on you can create a hole center randomly on a face which is exactly what I'm trying to do.
However it is not selecting anything when I hover anywhere on the part.
This can't be that hard. Sheesh.
Replies (7)
Message 2 of 8
AndrewHumiston
hey we all have those days where things are screwy. can you upload the part so i can take a look at what you are seeing please.
Message 3 of 8
gak19043
Thanks. After realizing this may not be on the right forum I re-posted under just the Inventor board. And u can see my and others replies. At the end of the day, I suddenly for no apparent reason on my part, was able to suddenly be able to select a face. Now I'm struggling with positioning it with respect to two edges as holes usually are.
Message 4 of 8
gak19043
I am able to position it with respect to one edge but can't figure out how to get it to select the other edge to dimension from. Sigh.
Message 5 of 8
AndrewHumiston
the best workflow i've found for that is, to create a sketch first then use the hole command, i know that can be cumbersome but its the best way i've found to get a consistent result.
like if you agree please.
Message 6 of 8
Stakin
Sub main()
Dim oPrt As PartDocument
oPrt = ThisApplication.ActiveDocument
Dim oHole As HoleFeature
Dim oPdef As PartComponentDefinition
oPdef=oPrt.ComponentDefinition
Dim oEdge1 As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Linear Edge 1")
Dim oEdge2 As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select Linear Edge 2")
Dim oPlane As Face =Nothing
If oEdge1 Is Nothing Or oEdge2 Is Nothing Then
	MessageBox.Show("UnLess 2 edges Selected!Exit!", "Title")
	Exit Sub
Else
	Dim oLine As LineSegment = oEdge1.Geometry
	For Each ofc As Face In oEdge1.Faces
		If ofc.Edges.cast(Of Edge).Where(Function(oEd) oEd Is oEdge2).Count=1 Then
			oPlane = ofc
			Exit For
	Next
	If oPlane Is Nothing Or oLine.IntersectWithCurve(oEdge2.Geometry).Count = 0 Then
		MessageBox.Show("The edges are not on same face or coplanar,exit!", "Title")
	Else
'		MessageBox.Show("Successful selected,Be Create HoleFeature", "Title")
Dim oBiasPoint As Point
oBiasPoint=oPdef.MassProperties.CenterOfMass
Dim oLhdef As LinearHolePlacementDefinition
oLhdef = oPdef.Features.HoleFeatures.CreateLinearPlacementDefinition(oPlane, oEdge1, "1.5 cm", oEdge2, "1.5 cm", oBiasPoint)
oHole=oPdef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oLhdef,"1 cm",PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
End Sub
Try, and also refer to the sample "Hole feature linear placement".
Public Sub HoleFeatureLinearPlacement()
    ' Create a new part document, using the default part template.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                 ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Set a reference to the component definition.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Create a new sketch on the X-Y work plane.
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(3))
    ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    ' Create a square on the sketch.
    Call oSketch.SketchLines.AddAsTwoPointRectangle( _
                                        oTransGeom.CreatePoint2d(0, 0), _
                                        oTransGeom.CreatePoint2d(6, 6))
    ' Create the profile.
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    ' Create an extrusion.
    Dim oExtrudeDef As ExtrudeDefinition
    Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
    Call oExtrudeDef.SetDistanceExtent("2 cm", kNegativeExtentDirection)
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
    ' Get the start face of the extrude.
    Dim oFace As Face
    Set oFace = oExtrude.StartFaces(1)
    ' Get two adjacent edges on the start face.
    Dim oEdge1, oEdge2 As Edge
    Set oEdge1 = oFace.Edges(1)
    Set oEdge2 = oFace.Edges(2)
    ' Create a bias point for hole placement to place it at
    ' the expected location. This is the model point
    ' corresponding to the center of the square in the sketch.
    Set oBiasPoint = oSketch.SketchToModelSpace(oTransGeom.CreatePoint2d(1.5, 1.5))
    ' Create the hole feature placement definition.
    Dim oLinearPlacementDef As LinearHolePlacementDefinition
    Set oLinearPlacementDef = oCompDef.Features.HoleFeatures.CreateLinearPlacementDefinition _
    (oFace, oEdge1, "2 cm", oEdge2, "2 cm", oBiasPoint)
    ' Create the hole feature.
    Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent( _
                            oLinearPlacementDef, "1 cm", kPositiveExtentDirection)
End Sub
Message 7 of 8
gak19043
Hey thanks for that but I am not a programmer just a long time user (decades) of AutoCAD and a new student of Inventor (sort of).  I reposted this on just the Inventor forum after realizing I mistakenly placed this on this "programming" forum of Inventor. So, I appreciate your effort and apologize for causing you to work out something for me that I may or may not know how to implement.
Message 8 of 8
gak19043
Thanks for all of the advice. I figured this out.
