Can't change iPart by iLogic
nalofoxdu04
nalofoxdu04
Good morning
I can't get my career change to work with iLogics.
Here is my ipart and my assembly
Can you have idea what is not working ? thank
WCrihfield
Will it allow you to make that change manually (without using an iLogic rule)?  If it will let you do it manually, then does it show any warning type dialog during that process.  If so, you may have to run the rule with its 'Silent Operation' option turned on, to avoid that potential warning or dialog.  Also, in your rule code, you are only including the first two inputs being requested.  That iPart.ChangeRow method is requesting at least 3 inputs.  The third input is an array of Object, indicating some unique row cell values, I believe.
Wesley Crihfield
(Not an Autodesk Employee)
A.Acheson
Hi @nalofoxdu04
The parent assembly looks like an iassembly and this will not support ilogic rules for changing members. You need to add the ipart configuration table to the iassembly table and change the member when in memberscope mode.
Regards
Alan
nalofoxdu04
Thank for your help,
