Can't access Part Document from Assembly if Part is not previously set to Master Model State
logan.andersonD3CSK
logan.andersonD3CSK
I have an iLogic rule that will place multiple model states of a part file into an assembly, and everything works perfectly as long as the part document has the master model state active, but if any other model state is active, the rule throws an error.
To see majority of the code I am using, see the solution for this forum: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/find-names-of-all-model-states-in-co...
In particular, the line of code that throws the error is:
Dim oPDoc As PartDocument = ThisApplication.Documents.ItemByName(filepath)
' filepath is a string with the filepath to the part document on my computer set earlier in the code
The error I get is:
Due to the error occurring at this point in the rule, I am unable to activate the master model state in the part document via the rule to circumvent this error.
  Is anyone else having a similar issue? (I'm trying to figure out if this is a bug in Inventor's programming that can get fixed in an update down the road.)
Ralf_Krieg
Hello
Can you try this? It's untested, so please save before.
If oPDoc.ComponentDefinition.IsModelStateMember Then
    oPDoc=oPDoc.ComponentDefinition.ModelStates.ActiveModelState.FactoryDocument
R. Krieg
RKW Solutions
www.rkw-solutions.com
CattabianiI
From the ItemByName manual, the filepath parameter is:
Input String that specifies the Document to return. If only the FullFileName is specified for part and assembly documents, the master document within the file is returned (if it exists in the collection).
In your case you specified a full file name which correspond to the master/primary model state which you'll not have opened.
I don't get from the linked post which is the complete rule, but you could loop through the Application.Documents and compare doc.FullFileName with filepath to get the file you want to work with.
@Ralf_Krieg
The if in your snippet is after the error.
