Can not creat rule - error: could not find .dll
daan.ballieu
daan.ballieu
When i want to creat a new rule and save it, this error comes up:
every time it is a different dll-file
It use to work just fine.
I have tryed a reinstallation of inventor 2022, no luck, the same problem.
Could somebody please help me.
A.Acheson
Can you post the rules contents?
Regards
Alan
daan.ballieu
sure, but it does the same with a 'empty' rule , let say, just  : ' test
in the first line.
JelteDeJong
It's very strange for a program to look for a DLL in a temp folder. I did a search for the DLL on my system but could not find it. Therefore I would expect that it is not a native Inventor/iLogic dll.  Do you recognise the DLL name from some 3e party program? Did you try to disable all addins? Did you try the "Inventor reset utility"? (Probably that will not help because you already reinstalled Inventor but you can give it a go. Maybe it cleans your registry better than a reinstall...)
Jelte de Jong
Blog: hjalte.nl - github.com
daan.ballieu
the name that is given to te DLL is random, I did a clean uninstall and a reset to default urlier.
daan.ballieu
Jelten,
I did not turn off the add-ins yet, i'll give it a try.
thanks for your button creator by the way.
