Can not compare part number and the name of parameter
ngocson8335
ngocson8335
Dear Expert,
I can not compare part number of a part and the name of a parameter. Please help me to fix this problem.
Here is my code. Thank you.
SyntaxEditor Code Snippet
Imports Inventor.CustomPropertyPrecisionEnum
Imports Inventor.CustomPropertyTypeEnum
Dim oPart As PartDocument
oPart = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPart.ComponentDefinition
oFeatures = oCompDef.Features
Dim oParameter As Parameter
oModelParams = oCompDef.Parameters
i = 1
For Each oParameter In oModelParams
    Dim oPartNum as String = iProperties.Value("Project", "Part Number") & ":" & If (i < 10, "0" + CStr(i), CStr(i)) & ":Height"
    If oParameter.Name = oPartNum Then
        Select Case sName
    Case oPartNum
            oModelParams.Item(i).ExposedAsProperty = True
            oModelParams.Item(i).CustomPropertyFormat.PropertyType = kTextPropertyType
            oModelParams.Item(i).CustomPropertyFormat.Precision = kThreeDecimalPlacesPrecision
            oModelParams.Item(i).CustomPropertyFormat.ShowLeadingZeros = False
            oModelParams.Item(i).CustomPropertyFormat.ShowTrailingZeros = False
            oModelParams.Item(i).CustomPropertyFormat.ShowUnitsString = True
            oModelParams.Item(i).CustomPropertyFormat.Units = "mm"
    End Select
    i = i + 1
Next
Ngoc Son
Autodesk User
Mark.Lancaster
@ngocson8335
iLogic needs, issues and etc need to be posted in the Inventor Customization forum for best results.
I will have the moderator relocate your posting there to better suit your needs.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
ngocson8335
Thank you, @Mark.Lancaster
Ngoc Son
Autodesk User
mcgyvr
You are incrementing to the part number such that it never matches the parameter..
In your loop print out (messagebox.show) the part number and parameter that you are comparing and you will see the problem right away..
Thank you, I fixed this problem.
Ngoc Son
