Hi guys I’m especially new to ILogic and I have a question. I have a sketch that is a simple rectangle with two model parameters-simply the width and length dimensions of the rectangle. I want to be able to automatically bring in components that are controlled by both model parameters. For instance if the sketch is a 32’ by 24’ rectangle, I would like for 4 of the same components to automatically be added, 2 at 32’ length and 2 at 24’ length. I see that after running the add component rule, you can bring your part into the assembly. I’m trying to see if my model parameters can be detected and automatically add those parts into the assembly. That way I can modify the shape of the sketch(maybe creating 4 or 5 model parameters), and potentially, automatically add more parts to my assembly.
