Can iLogic set Simplify options?
andrew_canfield
andrew_canfield
Hello
Can these options be selected using iLogic?
Regards
Andrew
WCrihfield
Hi @andrew_canfield.  I think that tool is provided by a new 2022 Inventor Add-In called 'BIM Simplify' in the Add-In Manager dialog.  I suspect you would have to do some investigatory work into the reference dll file they specify:
C:\Program Files\Autodesk\Inventor 2022\Bin\FRxApplication.dll
, in order to extract more info about interacting with it by code...if possible.
I don't recall seeing any new API objects/methods for this yet...unless maybe it has something to do with the new RevitExports under the AssemblyComponentDefinition.
Wesley Crihfield
(Not an Autodesk Employee)
tyler.warner
Hey @andrew_canfield it looks like @WCrihfield was correct about it being the new Revit Exports.
RevitExportDefinition Object (Autodesk Help 2022)
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-
Create Revit Export Sample (Autodesk Help 2022)
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-E7A8BC92-DAD7-4AE3-9541-A58C2188561B
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
