Can iLogic print .txt of .xls?
machiel.veldkamp
machiel.veldkamp
Can you print files with iLogic other than IV drawings?
I have a rule which finds all drawings from an assembly and prints/exports them.
Now I got the question if we can add a print of the BOM of that.
I already can make a .txt files which is placed in the same folder as the export.... Now on to print it!
Is this even possible within inventor?
___________________________
machiel.veldkamp
Anyone know this?
DRoam
Are you wanting to actually execute a "print" to a physical printer, or export to a PDF? Or something else?
Are you wanting this print/export to be of the BOM itself, or of the TXT file your code makes?
machiel.veldkamp
I want to print the txt my code itself makes.
GeorgK
Imports System.IO
Dim path As String = "c:\temp\MyTest.txt"
RawPrinterHelper.SendStringToPrinter("WindowsPrinterName", File.ReadAllText(path))
