After seeing no one else has seemingly answered this question anywhere else I needed to find out this answer for myself and to help others who've asked this question.
Autodesk, it would be great to have a Visibility function added to the NamedEntities iLogic interface somewhere so we don't have to utilize these workarounds.
When named entities are inside a part there are two attribute sets added to the part document and each one contains one attribute inside:
Each of those attributes is a string value that lists the names of the entities delimited by Tab (you can use Chr(9) to insert a tab into your string):
Therefore you can get that value and change it or build a new string value and apply it to those attributes values to either change the order they're listed or change which ones are visible or not.
For example, if you apply a blank string to iLogicEntityNamesVisible then all named entities will be invisible.
After applying the changes to any of those strings you need to trigger a document save to make those changes happen in the model.
*This example code assumes the document was already previously saved with a Face, Edge, and Vertex already named the default names of Face0, Edge0, and Vertex0 respectively.
Dim oDoc as PartDocument = ThisDoc.Document
oDoc.AttributeSets("iLogicEntityNameSet")("iLogicEntityNamesOrdered").Value = "Face0" + Chr(9) + "Edge0" + Chr(9) + "Vertex0"
oDoc.AttributeSets("iLogicEntityNameSetTransient")("iLogicEntityNamesVisible").Value = "Face0" + Chr(9) + "Edge0"
oDoc.Save
@pmartick, building on what you provided, here is a rule to toggle all of the entities on/off
Dim oDoc As PartDocument = ThisDoc.Document Dim oNames As NamedEntities = iLogicVb.Automation.GetNamedEntities(oDoc) For i = 1 To oNames.Entities.Count EntName = oNames.Entities.Name(i) Dim EntValue As Object = oNames.Entities.Value(EntName) ObjectType = [Enum].GetName(GetType(ObjectTypeEnum), EntValue.type) 'Logger.Info(ObjectType) If ObjectType.Contains("Work") Then Continue For 'skip work objects If i = 1 Then sString = EntName Else sString = sString + Chr(9) + EntName End If ' Logger.Info(EntName) ' Logger.Info(sString) Next oAttSet = oDoc.AttributeSets("iLogicEntityNameSetTransient")("iLogicEntityNamesVisible") oHidden = (oAttSet.Value = "") If oHidden = False Then oAttSet.Value = "" Else oAttSet.Value = sString End If If Not oDoc.FullFileName = "" Then oDoc.Save
