Can I run the Open Drawing From Vault command in ilogic?
david_lowndes
david_lowndes
Hi have searched the forums but cannot find the specific answer to this question.
Is it possible to run the "Open Drawing From Vault" command shown it the picture using ilogic?
A.Acheson
Hi @david_lowndes
You can pick up the command names from the last post on this article here. That article also has the method to execute the control definition. There is a VBA version here in the API help but no VB.NET version.
In advance of pressing  that button by code does it fetch the drawing directly after the button is pressed? If it needs to go through other commands/dialogue then your automation workflow might not work.
Regards
Alan
david_lowndes
@A.Acheson thank you for your help with this.
I believe the command I need to run is
ThisApplication.CommandManager.ControlDefinitions.Item("VaultOpenDesignDocFromVault").Execute
And this worked.....the first time! But every time I have run it subsequently it doesn't work. It doesn't give an error, just does nothing!
A.Acheson
It might be the case you need to manually have the document selected. Either click on the browser node if in an assembly or open the document exclusively and selected the browser node and see if it runs. If this turns out to be the issue then you can selected the document by code using selectSet or Command Manager Do Select
ThisApplication.CommandManager.DoSelect(oOccurrence)
Regards
Alan
david_lowndes
Yes! That's the solution!
Doesn't work if I accept the top node, but does for all the children! Thank you for your help.
