Can I know the id of ribbon button is hovering
SandmanINV
SandmanINV
Hi everyone,
Like my title topic, i want to know id of button which mouse is hovering on it.
Can I do this ?
Please give me some advise.
Dev_rim
If there is something like that it would be "event". I'm working with events in my Add-in but i did not see anything like this. You can state active ribbon and then reach the all properties of tabs, panels, buttons.
Read about User Interface Manager in Inventor API.
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
SandmanINV
Thank you for your reply,
I can create my custom ribbon, Ok.
But, I have something which i need to know what button is hover on it.
These buttons maybe are Default of inventor, or my custom buttons. Mybe i have to think about another way.
JelteDeJong
You can run this iLogic rule and have a look at the file: "c:\temp\buttons.txt". It will contain all ribbon, tab, panel and control(/button) information
Dim lines As List(Of String) = New List(Of String)
For Each ribbon As Ribbon In ThisApplication.UserInterfaceManager.Ribbons
    lines.Add("Ribbon: " & ribbon.InternalName)
    For Each tab As RibbonTab In ribbon.RibbonTabs
        lines.Add("   Tab: " & tab.DisplayName & " - " & tab.InternalName)
        For Each panel As RibbonPanel In tab.RibbonPanels
            lines.Add("      panel: " & panel.DisplayName & " - " & panel.InternalName)
            For Each control As CommandControl In panel.CommandControls
                lines.Add("         control: " & control.DisplayName & " - " & panel.InternalName)
            Next
        Next
    Next
Next
Dim lines2 As List(Of String) = New List(Of String)
For Each item As String In lines
    lines2.Add(item.Replace(Constants.vbCr, " ").Replace(Constants.vbCrLf, " "))
Next
System.IO.File.AppendAllLines("c:\temp\buttons.txt", lines2)
Jelte de Jong
Blog: hjalte.nl - github.com
