Can I edit multiple hatch patterns?
Message 1 of 1
When you select a hatch and right-click, the context menu shows the "Edit..." command, and when you click it, you get the Edit Hatch Pattern dialog.
But if you select multiple hatch and right-slick, the "Edit..." command is disabled.
1. Is there some way I can add support for editing multiple hatch patterns?
2. Also, Is there a way for me to trigger the Edit Hatch Pattern dialog from my add-in code?
Replies (0)
