can I add an VBA form into a dockeble windows?
Darkforce_the_ilogic_guy
Advisor Advisor
can I add an VBA form into a dockeble windows? I have this form in VBA
I would like to get it to dock ...I know it is possible to make an form in ilogic .. that create a windows  that can dock .. I would like my form to dock as  well like any other things in inventor .. how do I do this ?  I have this code in iloigc that might help .. but I need the form Ktool into an windows and it need to be an VBA form ..
Dim oUserInterfaceMgr As UserInterfaceManager
        oUserInterfaceMgr = ThisApplication.UserInterfaceManager
        ' Create a new dockable window
        Dim oWindow As DockableWindow
        oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "TestWindowInternalName", "Test Window")
        ' Get the hwnd of the dialog to be added as a child
        ' CHANGE THIS VALUE!
        Dim hwnd As Long
        hwnd = 4851096
        ' Add the dialog as a child to the dockable window
        oWindow.AddChild(hwnd)' Her I would Like To add a UserControl Or Userfrom!!!!!
        ' Don't allow docking to top and bottom
        oWindow.DisabledDockingStates = DockingStateEnum.kDockTop And DockingStateEnum.kDockBottom
        ' Make the window visible
        oWindow.Visible = True
JelteDeJong
I expect that you can. The help files even have a VBA example.
Edit:
Sorry didn't read correctly I assume you found the help file already.
Jelte de Jong
Blog: hjalte.nl - github.com
I have seen that code before but I do not know have to add my form to the windows
Ralf_Krieg
Hello
It is possible. The problem is, a VBA form doesn't have a hwnd property by default. Take a look at the last post in this thread.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/add-in-dockable-window/td-p/7107964
R. Krieg
RKW Solutions
www.rkw-solutions.com
