can anyone tell me where the extra number come from ?(ilogic)
Darkforce_the_ilogic_guy
Advisor Advisor
My code look like this
ExcelPath  = "C:\Working Folder\CAD\Kallesoe\Kallesoe iLogic\Underdevelopment\ProjectRequirements.xlsx"
	ExcelSheet = "Ordre"
	Dim NameList As New ArrayList()
	GoExcel.Open(ExcelPath, ExcelSheet)
	For i = 3 To 4
		NameList.Add(NameList.Add(GoExcel.CellValue(ExcelPath, ExcelSheet, "A"& i)))
	'MessageBox.Show(NameList.Add("Raw")), "Title")
	'MessageBox.Show(GoExcel.CellValue(ExcelPath, ExcelSheet, "A3"), "Title")
Next
	'NameList.Add(GoExcel.CellValue(ExcelPath, ExcelSheet, "A3"))
	GoExcel.Close
	Dim msg As String
	msg = ("Surface needed - Select Surface " & vbLf & "Part Numner: "+iProperties.Value("Project", "Part Number")& vbLf & "Description: "+iProperties.Value("Project", "Description")& vbLf & "Title: "+ iProperties.Value("Summary", "Title")& vbLf).ToString
	d0 = InputListBox(msg, NameList, d0, Title := "Info - Surface needed", ListName := "Surface")
I only thing there should come an inputlistbox with 2 linje .. but 4 it coming and the 0 and 2 should not be there as far as i now. can anyone tell me why they are there ? and how to fix it
NachoShaw
without bit more info its hard to say but at a very top level first glance, are you adding 2 rows per call?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
the cell does not ...but the cell that I an use to as main title does. can it still be that and is the a way it not show thoes extra nummer and still keep the titles ?
NachoShaw
how are you adding the list to NameList to the Listbox? You are adding 2 entries on that code line and whatever code you use to populate the listbox is just showing the NameList array. If you only want to show the titles, why dont you just add the titles only?
Nacho
WCrihfield
Maybe try replacing the '+' plus signs in your msg with '&' signs?
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
Hi @Darkforce_the_ilogic_guy
I'm not sure I understand what it was doing, but this version gave me the expected list.
I hope this helps.
Curtis
Dim oNameList As New ArrayList()
For i As Integer = 3 To 4
	'MsgBox(i)
	oValue = GoExcel.CellValue(ExcelPath, ExcelSheet, "A"& i)
	'MsgBox(oValue)
	oNameList.Add(oValue)
Next
Dim msg As String
msg = ("Surface needed - Select Surface " & vbLf & _
"Part Numner: " + iProperties.Value("Project", "Part Number") & vbLf & _
"Description: " + iProperties.Value("Project", "Description") & vbLf & _
"Title: " + iProperties.Value("Summary", "Title") & vbLf).ToString
d0 = InputListBox(msg, oNameList, d0, "Info - Surface needed", "Surface")
GoExcel.Close
