Can a 64-Bit Add-in reference a 32-Bit dll ?
stuartmp
stuartmp
Hi all,
I am witting a Add-in in VB.Net 2008.
I have attach a 32-bit ActiveX Dll that was written in VB6.
The project loads fine in Inventor 2009 32-bit & Inventor 2010 32-bit.
Although I am having trouble getting it to load in Inventor 2009 64-bit & Inventor 2010 64-bit.
I have written many 64-bit Add-ins before and have had no issues.
I am registering the 32-bit ActiveX Dll from VB6 with regsvr32 ABCD.dll
I am registering the Interop.ABCD.dll that vb.Net creates into the Global Assembly Cache
Finally I am registering the vb.Net Addin Dll with C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase ABCD.dll
All returned no errors
As I said before the project runs fine in Inventor 2009 32-bit & Inventor 2010 32-bit using
regsvr32 ABCD.dll
registering the Interop.ABCD.dll into the Global Assembly Cache
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe /codebase ABCD.dll
So I guess my question is.
Is it possible to create a 64-Bit Add-ins referencing 32-Bit dlls ?
If so where am I going wrong?
Thanks in Advance
Stuart.
jeff.pek
Hi Stuart -
I think the only way you'll be able to do this is by using an out-of-process COM server for your 32-bit code. The 64-bit code can then instantiate it, and the system will take care of marshaling between the now-separate processes. If you're using the ActiveX DLL as a control, this might be a problem, performance-wise, so the feasibility of doing this depends on what job(s) the DLL is performing.
Jeff
stuartmp
Thanks for response Jeff.
I no nothing about "out-of-process COM server's"
What involved in writing some .net code for this?
I have my project running in 64-Bit using a compiled EXE I created in VB6.
It is a quite a bit slower than the Dll that runs in 32-bit.
If I when to the effort to create the out-of-process COM server would it be any faster that the EXE that I have already created?
if so, I guess I also have to weigh up any performance gains with the work involved creating the out-of-process COM server.
if not, I may as well put that same effort in to converting the VB6 Dll to .net
Thanks again for the response
Stuart
