Calling the main Assembly and its copy without changing the main Assembly
mohnish_soral
mohnish_soral
In the above figure I am placing the door at location read by my Json file using Inventor API
The parts are placed at the location lets say C:\abc\def , so I call the main part and then create the copy of that part by the code shown below , now in this file path mention above I have the door assembly folder in which door and its assembly is placed which then called and get placed as we can see in above figure.
Code is :
foreach (var entry in parameters) // Variable entry is created and the JSON data gets asssign one by one to it
string partName = entry.Key; // Part name inorder to pass it to string and run in common loop
List<ComponentOccurrence> componentList = new List<ComponentOccurrence>();
int index = 0;
string location;
if (files_component.Contains(partName + ".ipt"))
location = IOPath.Combine(inputFilesDir, partName + ".ipt"); // this is used to open the file in input directory
else
location = IOPath.Combine(inputFilesDir, partName + "_assembly\\" + partName + ".iam"); // this is used to open the door.iam files in the input directory
foreach (var componentData in entry.Value) // It takens the value and pass it to component data and that starts assigning values to transformation matrix
Matrix transformationMatrix = TransformationMatrix(componentData); // transformation matrix is taken from Matrix creation
ComponentOccurrence componentOccurrence = null;
if (index == 0)
componentOccurrence = asmDoc.ComponentDefinition.Occurrences.Add(location, transformationMatrix); //Placing the original part firstly and then moving to else part for create copy method
componentList.Add(componentOccurrence);
document = (Document)componentOccurrence.Definition.Document;
else // It is use to create the copy after first part is place
componentOccurrence = create_copy_component(asmDoc, transformationMatrix, componentList[0], partName + index.ToString(), location); // it creates the copy of the component and then place in Inventor
private ComponentOccurrence create_copy_component(AssemblyDocument asmDoc, Matrix oPositionMatrix, ComponentOccurrence Component_, string name, string location)
Document partdoc = (Document)Component_.Definition.Document;
String CopiedFile ;
var docType = partdoc.DocumentType;
switch (docType)
case DocumentTypeEnum.kAssemblyDocumentObject:
var asm = partdoc as AssemblyDocument;
CopiedFile = name + ".iam";
break;
case DocumentTypeEnum.kPartDocumentObject:
var ipt = partdoc as PartDocument;
CopiedFile = name + ".ipt";
break;
default:
throw new ApplicationException(string.Format("Unexpected document type ({0})", docType));
String OrigFile = partdoc.FullFileName;
var component_dir = System.IO.Path.GetDirectoryName(OrigFile);// path to original file
// path to copied file
string Part_Path_copy_1 = System.IO.Path.Combine(component_dir, CopiedFile);
try
System.IO.File.Delete(Part_Path_copy_1); // use to delete the exisiting parts in the present directory
catch (IOException)
Console.WriteLine("The specified file is in use. It might be open by Inventor");
inventor_app.FileManager.CopyFile(location, Part_Path_copy_1, FileManagementEnum.kCopyFileMask); // API for the copied part and the return of that documnet which can be used in the above functions
ComponentOccurrence Copy_part = asmDoc.ComponentDefinition.Occurrences.Add(Part_Path_copy_1, oPositionMatrix) as ComponentOccurrence;
return Copy_part;
Now my question is when I change the json file and want that the door file should be placed twice instead of one
the first door gets placed perfectly , but as soon as the second door get placed , both the door changes their dimension
The first door converts itself two seconf door as seen in figure
Why this is so
Is this because I am using the same parts between the components
What can be the solutions ?
I have to also create the copy of that copy door parts if yes , so how can that door can recognized I have to take the copy parts only
Can someone please take me out from this
Thank you in advance
A.Acheson
Hi @mohnish_soral
For future reference this should be posted in the Ilogic/Vba forum as its a coding question.
From your description it sounds like you have placed the exact same part but you intended to have too seperate parts. If you want to have two seperate parts Perform a save as from inventor and then place the part. Check the filepaths. Don't perform any renaming in windows, the API has all the functions available.
Regards
Alan
