Calling all guru's
Calling all guru's
Message 1 of 9
Calling all guru's
Does anyone have a idea if it is possible to make a user form dockable? Or better yet
has anyone been able to do it? If so ... mind sharing
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Replies (8)
Message 2 of 9
oooh, oooh, I've been wondering about that one myself...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:5ABF7BAEE8B15295FB482338C11CD0FD@in.WebX.maYIadrTaRb...
Or better yet
> Kent
> Assistant Moderator
Message 3 of 9
I second that. This could be very useful. Does anyone know how to...
Mike
__________________
Michael V. Ficarra
Engineering Manager
Cross Bros. Co. Inc.
(585) 427-7850 x207
(585) 427-2908 (Fax)
(585) 233-6653 (Cell)
"Sean Dotson" wrote in message
news:291FC83A451C373BF5F5A2A7CBE6D9EE@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> Or better yet
> > Kent
> > Assistant Moderator
Message 4 of 9
You will probably need to make a browser pane. This will require
creating an OCX. There is an example of one in the VB Samples and it is
documented in the programming help. I have done a couple that way.
>Kent
>Assistant Moderator
Message 5 of 9
You mean make a new browser pane in addition or in place of the current
browser. I know how to make one in place of the current browser (like the
library).
I'd like to know if it's possible to make it such that we could dock the app
and keep it visible while you still use the current browser.
Sean Dotson, PE
"Charles Bliss" wrote in message
news:3F3E692B.3050109@cbliss.com...
Or better yet
> >Kent
> >Assistant Moderator
Message 6 of 9
Also, can this be done in VBA or is it limited to VB?
Mike
__________________
Michael V. Ficarra
Engineering Manager
(585) 427-7850 x207
news:3F25477F25BDCA3F99DEC5C2B687604D@in.WebX.maYIadrTaRb...
> library).
app
> Sean Dotson, PE
> Or better yet
> > >Kent
> > >Assistant Moderator
Message 7 of 9
I am pretty sure that to do any of this you would require VB at the
minimum since you have to complie and OCX as the browser pane.
Message 8 of 9
I have pondered the same question Sean when trying to make a
floating/dockable window, unfortunately (as you say) the browser pane
implementation is flawed because you have to change the focus between your
own window in the pane and the Inventor one, which is not ideal.
The closest I came to getting something that was dockable was by using API
calls to determine the window geometry of the Inventor window itself and
setting the position of a floating window (inside an add-in DLL) accordingly
in a docked-to-the-left or docked-to-the-right position.
This was never satisfactory, unfortunately, because the window was only ever
floating on top and it never looked quite right... I would love to hear
about anyone that has had more success than me!
> library).
app
> Sean Dotson, PE
> Or better yet
> > >Kent
> > >Assistant Moderator
Message 9 of 9
Looks like there is a number of us that would like this ability. The
browser method is OK for some addin's , but definitely not for ones that
you want available all the time along with the normal browser.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
"J Smith" wrote in message
news:79F37F7C266B3BF9FB443CC42239EA24@in.WebX.maYIadrTaRb...
your
