calling a function from a c++ dll
I'm working inside the Inventor VBA Editor and trying to call a function from my own external c++ dll.
I can't seem to figure it out with the given info about this topic.
Could anyone guide me through the process?
Thanks in advance!
RichardErnstberger
Hi Sonny,
i do not waste any time with VBA in Inventor.
I have a large app inside Inventor (also C++ dll) and i do anything inside the dll.
Define commands, create ribbon buttons and tabs, do user interaction, do anything...
I strongly recommend you to avoid the VBA crap inside Inventor - it is in no way a must.
Most times VBA is quick and dirty.
I rarely use it for some short tests, but would not implement any production function in VBA.
But, i also have to deal with other products, where the native dll approach wont work as in Inventor.
Here's an example of a VBA module to access a remote dll in a very famous big CAD system 🙂
Hopefully it would work in Inventor also.
In the first line of your module, prior to any function declarations you have to place lines like this one
Private Declare PtrSafe Sub myfuncCallvba Lib "D:\\yourappdir\\your.dll" ()
You probably can omit the PtrSafe keyword
And it would be helpful to have yourappdir somewhere Inventor can find it.
A call to the declared funtion looks like this:
Call myfuncCallvba
Arguments (if you need) should work also, at least if you use standard types.
In my case i have a set of registry keys and variables where i place the argument values before calling the dll functions.
Hope that can help you.
RIchard
