Call or set custom parallel environment from VB.Net API button On_Execute cmd
01:30 PM
I'm having a little difficulty finding a code example in VB.Net to call or set my Add-in environment from a custom button placed on the zerodoc ribbon. The button command when clicked loads an assembly template and I want to include a call in the button On_Execute code to automatically set my parallel environment rather than have the user manually select the "Environments - <Custom Environment Name>" from the Environments ribbon tab.
The final aim of this command will be to set the custom environment automatically, only when a document that has a custom parameter embedded within it is flagged as true.
I cant seem to get the object browser prototypes or the API help examples to work at all......not sure why so I'm stuck
Cheers dudes
