Call iLogic from .NET c# (Inventor 2018)
C-Hoppen
Message 1 of 9
C-Hoppen
Hello, how can I get the automation from iLogic?
I found
https://adndevblog.typepad.com/manufacturing/2015/05/use-goexcel-outside-a-rule.html
https://adndevblog.typepad.com/manufacturing/2013/04/call-ilogic-from-net.html
but I could not do it with c#. Here is my code
 using Autodesk.iLogic.Interfaces;
public static IiLogicAutomation GetIlogicAutomation(Inventor.Application inventorApp) { IiLogicAutomation _iLogicAutomation = null; string iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"; Inventor.ApplicationAddIn addin = null; try { addin = inventorApp.ApplicationAddIns.get_ItemById(iLogicAddinGuid); } catch { } if (addin != null) { if (!addin.Activated) addin.Activate(); _iLogicAutomation = addin.Automation as IiLogicAutomation; _iLogicAutomation = (IiLogicAutomation)addin.Automation; <- //Invalid Cast Exception! } return _iLogicAutomation; } public static Autodesk.iLogic.Interfaces.iLogicRule GetiLogicRuleByName( IiLogicAutomation _iLogicAutomation, Inventor.Document oDoc, string ruleName) { Autodesk.iLogic.Interfaces.iLogicRule myRule = null; foreach (Autodesk.iLogic.Interfaces.iLogicRule eachRule in _iLogicAutomation.get_Rules(oDoc)) { if (eachRule.Name == ruleName) { myRule = eachRule; break; } } return myRule; } }
References:
..\Program Files\Autodesk\Inventor 2018\Bin\Autodesk.iLogic.Interfaces.dll
..\Program Files\Autodesk\Inventor 2018\Bin\Public Assemblies\Autodesk.Inventor.Interop.dll
image.pngAnyone have any suggestions or things I might try?
Christoph
Replies (8)
Message 2 of 9
JamieVJohnson2
in VB.Net I use this code:
 Dim iLogicAddInGUID As String = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
        Dim addin As Inventor.ApplicationAddIn = Nothing
        Try
            addin = invApp.ApplicationAddIns.ItemById(iLogicAddInGUID)
        Catch ex As Exception
            MsgBox("Unable to load iLogic Add In", MsgBoxStyle.SystemModal)
        End Try
        If Not addin.Activated Then
            addin.Activate()
        Dim strRuleCalcs As String = String.Empty
invApp.SilentOperation = True
        Dim iLogAuto As Object 'Autodesk.iLogic.Interfaces.IiLogicAutomation
        iLogAuto = addin.Automation
        iLogAuto.CallingFromOutside = True
        iLogAuto.EnterDelayedRuleRunningMode()
        Dim newRule As Object = iLogAuto.AddRule(Model, "Calcs", "")
        newRule.text = strRuleCalcs
        iLogAuto.ExitDelayedRuleRunningMode()
        iLogAuto.RulesOnEventsEnabled = True
        AssignRuleToILogicEvent(Model, "Calcs", "BeforeDocSave0", 700)
        invApp.SilentOperation = False
  Public Sub AssignRuleToILogicEvent(invDoc As Inventor.Document, ruleName As String, strEvent As String, strID As String)
        Dim customiPropSet As PropertySet = Nothing
        For Each propSet As PropertySet In invDoc.PropertySets
            If propSet.Name = "iLogicEventsRules" Then
                customiPropSet = propSet
                Exit For
            If propSet.Name = "_iLogicEventsRules" Then
                Exit For
        Next
        If customiPropSet IsNot Nothing Then
            If customiPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
                customiPropSet.Delete()
                customiPropSet = invDoc.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
        If customiPropSet Is Nothing Then
            MsgBox("Unable to create event triggers for this file.",, "Event Triggers")
        If customiPropSet IsNot Nothing Then customiPropSet.Add(ruleName, strEvent, strID)
    End Sub
Note, I set the variable type for the automation to 'object' aka 'var' in c#, because of the Inventor API system_com reponse to all object types, I can't use option explicit.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 3 of 9
c_hoppen
Thanks for the sample. You gave me an important hint. var doesn't work, but dynamic does.
        public static void TestIlogicAutomation(Inventor.Application inventorApp)
            try
            catch { }
            if (addin != null)
                    addin.Activate();
                /*IiLogicAutomation*/ dynamic _iLogicAutomation = addin.Automation;
                _iLogicAutomation.CallingFromOutside = true;
                _iLogicAutomation.DeleteRule(inventorApp.ActiveDocument, "Hauptabmessungen");
                //iLogicRule delRule = null;
                //foreach (iLogicRule eachRule in _iLogicAutomation.get_Rules(inventorApp.ActiveDocument))
                //    if (eachRule.Name == "Hauptabmessungen")
                //        delRule = eachRule;
                //        break;
                //if (delRule != null) _iLogicAutomation.DeleteRule(inventorApp.ActiveDocument, "Hauptabmessungen");
But there is still a lack of clarity.
this works:
this throws an exception:
Microsoft.CSharp.RuntimeBinder.RuntimeBinderException
System.__ComObject' does not contain a definition for get_Rules.
why?
Message 4 of 9
JamieVJohnson2
You will probably appreciate this:  get a copy of JetBrains dotPeek (its free).  Install, and open.  Copy the dll, then open your copy (so as not to disturb the peace):  Autodesk.iLogic.Automation.dll
Expand the list, and you will find iLogicAutomation.Rules(document doc):IEnumerable.  That is your way in.
Message 5 of 9
C-Hoppen
JetBrains dotPeek made my day. Thanks a lot!
Message 6 of 9
rikard.nilsson
Could you please share how you solved how to do a...
 foreach (Autodesk.iLogic.Interfaces.iLogicRule eachRule in _iLogicAutomation.Rules(oApp.ActiveDocument))
Because I still get an error after changing from "get_Rules" to "Rules".
Regards
Rikard
Message 7 of 9
C-Hoppen
Ricard, you have to use dynamic
            try
            catch { }
            if (addin != null)
                    addin.Activate();
                //_iLogicAutomation.DeleteRule(inventorApp.ActiveDocument, "Hauptabmessungen");
                /*iLogicRule*/ dynamic delRule = null;
                try
                    foreach (/*iLogicRule*/ dynamic eachRule in _iLogicAutomation.Rules(inventorApp.ActiveDocument))
                            delRule = eachRule;
                            break;
                catch
                    // will throw an exception when document has no rules
Message 8 of 9
rikard.nilsson
Thanks!!
That solved my problem!!
Message 9 of 9
Khoa_NguyenDang
@C-Hoppen
i have this problem
Although i have the Rule to delete in my Part
