Call 3D Grips command
fakeru
fakeru
Is it possible to call 3D Grips command with VBA?
Autodesk Inventor 2015 Certified Professional
bobvdd
I cannot directly find the command associated with 3D Grip (I am not even sure that there is any exposed through the API)
But why don't you use the "Direct Edit" command instead which does what 3D Grip does and much more.
Public Sub RunDirectEditCommand()
    ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Get control definition for the Direct edit command.
    Dim oControlDef As ControlDefinition
    Set oControlDef = oCommandMgr.ControlDefinitions.Item("PartDirectCmd")
    ' Execute the command.
    Call oControlDef.Execute
End Sub
Cheers
Bob
Bob Van der Donck
Principal UX designer DMG group
fakeru
I need this in context of medium to large assemblies and then the direct edit commands are very slow...
bobvdd
If you open the part document in a new window, performance should not mtter that much but it might hamper a more seamless flow of the app.
Bob
Bob Van der Donck
fakeru
You are right, but such the meaning of the addin I'm working on that it must call the command in assembly enviroment. And usually it will happen in large assemblies.
