Calculate string expression
rikard.nilsson4SLAL
rikard.nilsson4SLAL
I'm trying to calculate an expression in a string to create a double in iLogic.
I've done som e searching and I think is DataTable is the best way of solving that. I try with the the row below.
result = New DataTable().Compute("1 + 2 * 7", Nothing))
 But I get that DataTable is not defined..
I tried with different imports like..
Imports System.Data
But nothing works.
Does anybody know what I should import to get this working in iLogic or do anybody have another solution how to calculate string expressions?
Regards
Rikard
FINET_Laurent
Hello @rikard.nilsson4SLAL,
You need to add the references first before importing the class :
AddReference "System.Data.dll"
AddReference "System.Xml.dll"
Imports System.Data
Imports System.Xml
Sub Main()
    Dim expression As String = "1 + 2 * 7"
    Dim result As Object = New DataTable().Compute(expression, Nothing)
	MsgBox(result)
End Sub
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
rikard.nilsson4SLAL
Yes of course!!
Thank you so much!
/Rikard
