C# WindowSelect not working
Message 1 of 1
I am working with a pointcloud object.
I am trying to select multiple PointCloudPoints through a windowselect with interactionevents. I have tried following/translating the sample given in the API to C#. My code works for selecting single points, but not for window-selecting multiple. (see photos)
What needs to change for the windowselect to work as intended?
Selecting a single point highlights and displays count message (fires onselect handler):
Window selecting does not highlight anything or fire onselect handler:
The code:
class PCWindowSelector
        private Application inv;
        private InteractionEvents interactEvents;
        private SelectEvents selectEvents;
        private bool bShowTooltip;
        public PCWindowSelector(Application _inv)
            inv = _inv;
            interactEvents = inv.CommandManager.CreateInteractionEvents();
            interactEvents.InteractionDisabled = false;
            interactEvents.SelectionActive = true;
            interactEvents.Name = "PC Window Select Interaction";
            selectEvents = interactEvents.SelectEvents;
            selectEvents.OnPreSelect += new SelectEventsSink_OnPreSelectEventHandler(selectEvents_OnPreSelect);
            selectEvents.OnSelect += new SelectEventsSink_OnSelectEventHandler(selectEvents_OnSelect);
            interactEvents.OnTerminate += new InteractionEventsSink_OnTerminateEventHandler(InteractionEvents_OnTerminate);
            selectEvents.AddSelectionFilter(SelectionFilterEnum.kPointCloudPointFilter);
            selectEvents.WindowSelectEnabled = true;
            bShowTooltip = inv.GeneralOptions.ShowCommandPromptTooltips;
            inv.GeneralOptions.ShowCommandPromptTooltips = true;
            interactEvents.StatusBarText = "Window select. Esc to exit";
            System.Diagnostics.Debug.WriteLine("You are here 0");
            interactEvents.Start();
        private void InteractionEvents_OnTerminate()
            inv.GeneralOptions.ShowCommandPromptTooltips = bShowTooltip;
            selectEvents = null;
            interactEvents = null;
        private void selectEvents_OnPreSelect(ref object preSelectEntity, out bool doHighlight, ref ObjectCollection morePreSelectEntity, SelectionDeviceEnum selectiondevice, Point modelPosition, Point2d viewPosition, View view)
            doHighlight = true;
            //System.Diagnostics.Debug.WriteLine(morePreSelectEntity.Count);
        private void selectEvents_OnSelect(ObjectsEnumerator selectedEntities, SelectionDeviceEnum selectiondevice, Point modelPosition, Point2d viewPosition, View view)
            System.Diagnostics.Debug.WriteLine("You are here 2");
            System.Windows.Forms.MessageBox.Show(selectedEntities.Count.ToString() + " Points selected");
Replies (0)
