C#/FB.net: Using/Reading Constraint Limits
sebastian.Flierl7B6DQ
I would like to read the Value of ConstraintLimits.MaximumEnabled by using the API with a C# Code. (using visual Studio). I don´t get access to the ConstraintLimits by Using a C# Code. (same with FB.net). There is a difference to the VBA script.
If I use a VBA script i can do this with the following code:
Dim MaximumEnabled As bool
MaximumEnabled = oOcc.Definition.Occurrences.Constraints.ConstraintLimits.MaximumEnabled = True
If I use a C# script there is a Property "ConstraintLimits" for my Constraints but I don´t habe acess to it.  (see.Figure)
How can I use the ConstraintLimits with a C# Code?
What is the difference between C# and VBA in this case?
Using Autodesk Inventor Professional 2021 and Visual Studio 2019.
Hope someone can help me.
Thanks a lot.
Accepted solutions (3)
laszlo_nagy
I think "AssemblyConstraint" Object doesn't have this property ("ConstraintLimits")
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-BF70CF3D-0631-44FE-B31B-21E380F067FE
Only specified Constraint Objects have this property
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-F568FC0E-6CE0-4408-9713-091E7E9E8EDA
see the "Accessed From" List
laszlo_nagy
In VB you can do this way ( I don't know C#)
For each obj in  oTempOcc.Constraints
  bMaximumEnabled =  obj.ConstraintLimits.MaximumEnabled
next obj
(or you have to declare specific variable, with the right type)
Thank you for your answer.
I have to declare the variable with the right type in C#.
So if I understand correct, i have to do it like this:
1. Identify the type of the Assembly Constraint (AngleConstraint e.g.)
2. Then I can use a variable with the right type (AngleConstraint) to get acess to the ConstraintLimits.
I will try this and give you a feedback.
dutt.thakar
@sebastian.Flierl7B6DQ
I think you need to be quite specific with constraints here, See the below snapshot where I have tested with a Flush constraint in C# and Inventor 2021, I am able to access the property and also able to read the value as well.
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Thank you both for your answers. This really helped me.
Now i use a dynamic variable to avoid the differetiation of the specific constraints typs.
