C# drawing replace reference model
hwu
Message 1 of 22
hwu
I have drawing saved to different location, then need to replace its reference model (there is only one reference model). I am wondering if there are C# code to do this?
thanks,
HWU
Replies (21)
Message 2 of 22
yan.gauthier
in a drawing Document, you have access to the object DrawingDocument.File.ReferencedFileDescriptors which you have read/write access to it.
in VBA, I change my reference like this:
For Each oFileDescriptor In NewDrawingDocument.File.ReferencedFileDescriptors
    If oFileDescriptor.Fullfilename = DocToCopy.Fullfilename Then
        oFileDescriptor.ReplaceReference NewFilePath
Next oFileDescriptor
NewDrawingDocument.PropertySets.item("Design Tracking Properties").item("Part Number").Value = fso.getbasename(NewFile)
Properties").item("Creation Time").Value = Now()
NewDrawingDocument.DisplayName = fso.getbasename(NewFile)
Message 3 of 22
WCrihfield
In plain iLogic (which uses VB.NET) here is a single line of code to replace the referenced model of a drawing.
(This assumes a single model reference, not multiple.)
ThisDrawing.Document.Sheets(1).DrawingViews(1).ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference("C:\Temp\OtherFile.iam")
And here is an example that separates the variables out.
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oNewModelFile As String = "C:\Temp\OtherFile.iam"
Dim oFD As FileDescriptor = oDoc.ReferencedDocumentDescriptors(1).ReferencedFileDescriptor
oFD.ReplaceReference(oNewModelFile)
oDoc.Update()
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 22
hwu
Thank you, Yan,
I cannot convert  your code to C#.
Can you please have it in C#?
Best Regards,
HWU
Message 5 of 22
WCrihfield
Here is a single line of iLogic (VB.NET) code to replace the model reference within a drawing.
(This assumes just one model reference within the drawing.)
And here is a version that breaks things down into more variables.
Dim oInvApp As Inventor.Application = GetObject(,"Inventor.Application")
Dim oDrawDoc As Inventor.DrawingDocument = oInvApp.ActiveDocument
Dim oFD As Inventor.FileDescriptor = oDrawDoc.ReferencedDocumentDescriptors(1).ReferencedFileDescriptor
oDrawDoc.Update()
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Sorry.  When I originally posted, it stalled out and gave an error indicating it didn't go through, so I reposted, then found out the original went through.
Wesley Crihfield
Message 6 of 22
hwu
Thank you!
When I convert your code to C#, shows:
DrawingDocument.ReferencedDocumentDescriptors() cannot be used as method.
I have no idea how to fix this.
Best Regards,
HWU
Message 7 of 22
WCrihfield
Perhaps it just doesn't like the format.  Maybe it would work better if you replaced:
 with
ReferencedDocumentDescriptors.Item(1).ReferencedFileDescriptor
Or to break it down even further:
Dim oDDs As Inventor.DocumentDescriptorsEnumerator = oDrawDoc.ReferencedDocumentDescriptors
Dim oDD As Inventor.DocumentDescriptor = oDDs.Item(1)
Dim oFD As Inventor.FileDescriptor = oDD.ReferencedFileDescriptor
oDrawDoc.Update()
Sorry, I'm not as familiar with C# as I am with VB.NET, but here's my attempt at the C# version of this code:
Inventor.Application oInvApp = GetObject(,"Inventor.Application");
Inventor.DrawingDocument oDrawDoc = oInvApp.ActiveDocument;
String oNewModelFile = "C:\Temp\OtherFile.iam";
Inventor.DocumentDescriptorsEnumerator oDDs = oDrawDoc.ReferencedDocumentDescriptors;
Inventor.DocumentDescriptor oDD = oDDs.Item(1);
Inventor.FileDescriptor oFD = oDD.ReferencedFileDescriptor;
oFD.ReplaceReference(oNewModelFile);
oDrawDoc.Update();
Wesley Crihfield
Message 8 of 22
hwu
Thank you,
there is no "Item" for choosing after "oDDs".
Best Regards,
HWU
Message 9 of 22
AlexKorzun
You might use C# indexer, as :
ReferencedDocumentDescriptors[1]
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
Message 10 of 22
yan.gauthier
he is how to handle IEnumerator in C#
IEnumerator fileEnumerator = drawingDocument.ReferencedFileDescriptors.GetEnumerator();
//Set index at position 0
fileEnumerator.Reset();
while (fileEnumerator.MoveNext())
    if (fileEnumerator.Current is FileDescriptor fileDescriptor)
        fileDescriptor.ReplaceReference("FileString");
Message 11 of 22
hwu
Thank all of you!
the code has no any problem, but it does not do the job.
Best Regards,
HWU
Message 12 of 22
yan.gauthier
if you debug your code, do you get inside the if statement ?
Also, I just remembered that FileDescriptor.ReplaceReference works only if files share Ancestry. So the new file has to be a copy.
Message 13 of 22
hwu
No. Not get inside of if statement.
Message 14 of 22
yan.gauthier
what is the object held by current ?
Message 15 of 22
hwu
Thank you, Yan,
Nothing happened. just stuck there.
Do you have any ideas?
Best Regards,
HWU
Message 16 of 22
yan.gauthier
Hi, I tested the code, the output of that is a ReferencedFileDescriptor, not a FileDescriptor. It seems to be different from what you can get in VB.
          IEnumerator fileEnumerator = drawDoc.ReferencedFileDescriptors.GetEnumerator();
                    if (fileEnumerator.Current is ReferencedFileDescriptor referencedFileDescriptor)
                        //fileDescriptor.ReplaceReference("FileString");
                        referencedFileDescriptor.PutLogicalFileNameUsingFull("FileString");
I would try this method to see if it works.
Message 17 of 22
hwu
Thank you, Yan,
HWU
Message 18 of 22
hwu
Hi Yan,
I just get a different way to meet what I need:
1. Create an iLogic,  triggered by iProperty, to replace the referenced model
2. Using C# to save the drawing to a different location with different name, set new drawing with new Part Number
Hopefully can find a direct way to do this.
Best Regards,
HWU
Message 19 of 22
hwu
Our company IT guy creates above code for me and it works. In the past, the codes didn't work, I guess we didn't add "update()".
Message 20 of 22
talha.tufan523TD
Can you share code block of the Function called UpdateDrawingView?
