Buttons in TriadEvents MiniToolBar NOT responding after converting code from VBA to VB.NET
liminma8458
liminma8458
I am creating code to use TriadEvents on a purpose to precisely move a sketch3Dpoint in a sweep. The code performs well in VBA. Then I convert it to VB.NET.
In VB.NET,  at MiniToolBar, I want to click "tick" (to accept), or "apply", or "cancel", they are NOT responding. I have to right click the screen then use context menu buttons to complete it.
Does anyone know why and the fix?
Attached are the VBA and VB.NET code, also a video to demo it.
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
liminma8458
I also attach the models here for test
Limin
YuhanZhang
In Inventor SDK there is a VB.net sample for this, you can just reuse the code:
1. Install the DeveloperTools.msi in C:\Users\Public\Documents\Autodesk\Inventor 2021\SDK\. You can change the path if you have a different Inventor version.
2. Then you can find the sample: C:\Users\Public\Documents\Autodesk\Inventor 2021\SDK\DeveloperTools\Samples\VB.NET\Standalone Applications\Inventor\UserInteraction.
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
