Button Image Quality
mat_hijs
Message 1 of 11
mat_hijs
I have an Add-in with some custom buttons. Everything works fine, but for some reason I can't get some of the button images to look nice. Some of the images look pixelated even though the png that I use looks perfectly fine. Some of these png files are even exported from the existing buttons in Inventor so I don't understand this. This makes everything look very unprofessional. Most problems seem to come from white parts of the images.
@MjDeck Could you maybe shine a light on this? How does autodesk manage to get crisp images when we, or at least I, can't seem to get it?
Replies (10)
Message 2 of 11
Michael.Navara
It depends on implementation. But in general:
  • you should use different icon/image for small and large button and use appropriate image size.
  • For command buttons I usually use .ico files with two icons 16px and 32px and with transparent background and 32-bit color depth.
Message 3 of 11
mat_hijs
I am aware of the different sizes for small and large buttons. When you use .ico files, do you not have the problems I described?
Message 4 of 11
Michael.Navara
I have no issue with ICO files
Preview
Sample project where you can see, how it is implemented.
Inventor AddIn Debugger
Message 5 of 11
mat_hijs
I tried looking at that but since I don't know any C# I didn't get that much wiser to be honest. So far I also haven't really found a way to create an ico file with multiple sizes from multiple png files. How do you make your icons?
Message 6 of 11
Curtis_Waguespack
@mat_hijs
This might or might not help ( I'm not the best at creating nice looking buttons) .
When converting *.png using the PictureDispConverter,  the add-in will attempt to convert a white background and white voids to transparent, and as a result often leaves jagged outlines in the process.
If you're using the Inventor light mode, it's noticeable but maybe acceptable. If using dark mode the results are often really bad.
*.ico files typically contain multiple sizes and and handle the transparent areas differently/better.
What I do when using a *.png file these days.
I don't use white in the image, instead I use the inventor ribbon canvas colors, off white and dark gray as shown.
Example:
I would not use the one with the white background, I would set the backgrounds to pre-match the ribbon canvas for both dark and light mode.
white backgroundwhite backgroundoff white ( inventor ribbon color)off white ( inventor ribbon color)dark mode ribbon colordark mode ribbon color
So typically, if working with a *.png it would be better to have a light and a dark mode, so that Inventor isn't removing the background, because it does so poorly... at least that is my experience.
Hope that helps,
Curtis
Message 7 of 11
mat_hijs
I've already considered doing something like this too, but one issue I have with this is that I usually just want to use an existing icon from Inventor because it looks a lot more professional than when I would start something from scratch. If I open one of the existing icons that I exported to png and try to fill the background it already doesn't look great. I think this may have to do with semi transparent pixels. I'll have to try to convert the same images to ico and hope for the best.
Message 8 of 11
Curtis_Waguespack
I'm not sure how you are getting the images from Inventor now, but you can use a utility called "BeCyIconGrabber"  to harvest *.ico files from Inventor *.dll files, and then save them out as *.ico files you can use. That might be something to look into.
Message 9 of 11
mslosar
I don't either. If i need both i tend to add an icon16.ico and icon32.ico into my resources.
I can tell you i've put some 64's and 128's in by accident and they, uh, do not scale 🙂 One, i couldn't figure out why my icon kept coming in as a blue square. Took me too long to realize i exported a 128x128 by accident and the top left 16x16 was simply blue 🙂
I haven't had the issues with transparency, but, i also tend to make my own icons in Photoshop. Get the ico plugin and voila 🙂
Message 10 of 11
mat_hijs
Ok so first I tried to give the png files the same background as the Inventor ribbon. This gave a better quality, but when hovering over the button it looks weird because the icon doesn't change color like the rest of the button.
Then I tried to convert all my png files to ico files and this gives me a way better result.
I tried to find the code I used to get the png files from the controldefinitions, but I couldn't find it. I think I started off with a piece of code that @WCrihfield wrote and adapted it to export all of them, which is 3900 images (large, small, light theme and dark theme). I also couldn't find the piece of code I started from unfortunately.
Message 11 of 11
kresh.bell
Hi all,
for custom made buttons i use this tool here
It is very simple and works ok for me. For all icons .png files
