Button icon for Net7
wmgshurik
wmgshurik
This code works pretty well for Net Frameork 4.8:
Image largeImage = Image.FromFile(pathLarge);
Image smallImage = Image.FromFile(pathSmall);
IconLarge = PictureConverter.ConvertImageToIPictureDisp(largeImage);
IconSmall = PictureConverter.ConvertImageToIPictureDisp(smallImage);
PipeButtonDef = controlDefs.AddButtonDefinition(" Pipeline ", "PipeID", CommandTypesEnum.kNonShapeEditCmdType, "", "", "", IconSmall, IconLarge);
private class PictureConverter : System.Windows.Forms.AxHost
    PictureConverter() : base("") { }
    public static stdole.IPictureDisp ConvertImageToIPictureDisp(Image Image)
        if (null == Image) return null;
        return (stdole.IPictureDisp)GetIPictureDispFromPicture(Image);
But on Net7 platform I catch the exception in method "ConvertImageToIPictureDisp". Interface not supported.
Does anybody know alternative way to set an image to buttonDefinition?
bradeneuropeArthur
Change the framework to an earlier one like 3.5
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
wmgshurik
The problem could not be resolved. I had to work around the problem. One plugin(NetFramework4.8) makes icons, the other(Net7) subscribes to events.
