Building an assembly
tschaeferZNBXX
Advisor Advisor
tschaeferZNBXX
So I want to create a form that has predetermined sub assemblies that are then placed in a larger main assembly.  Anyone ever done this?  Can I do it and have to sub assemblies be placed in the correct place?
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
adam.nagy
Autodesk Support
Autodesk Support
You can use the Occurrences.Add method which also lets you specify the transformation matrix to be used for the placement:
http://modthemachine.typepad.com/my_weblog/2013/04/inventor-2014-api-for-the-new-joint-feature.html
It could also be worth having a look at this:
http://adndevblog.typepad.com/manufacturing/2013/07/occurrences-contexts-definitions-proxies.html
Cheers,
Adam Nagy
Autodesk Platform Services
