Bug / weird results when setting diameter dimension position
basautomationservices
Hello all,
I'm programmatically updating the text position of a DiameterGeneralDimension.
The weird thing is that when I repeatedly run the code, the position changes every time, while I'm supplying the same points.
I've tested the point coordinate by creating a sketch, the point I'm supplying is not changing and is at the correct location.
Attached is 2 gifs that show that the dimensions move, when the exact same coordinates are supplied to the textpoint. Also weird is that both gifs (view in same pos, same Point2d set as text position) have different results.
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
daltonNYAW9
