BrowserPanes.
BrowserPanes.
BrowserPanes.
Can someone tell me how to add a BrowserPane in a simple way?
The sample does only explain how to use a Form that contain the ocx file.
I have already created a "Add-in" that I would like to add a ocx
(calculator) in the BrowserPane without any Forms if possible.
Lars Andersson
Det här kanske kan hjälpa... 🙂
Option Explicit
Implements ApplicationAddInServer
Private oApp As Inventor.Application
Private oDoc As Inventor.Document
Private WithEvents oAppEvents As ApplicationEvents
Private oPane1 As BrowserPane
Private oPane As BrowserPane
Private WithEvents MyMenu As MyMenu.MyMNU
Private Sub ApplicationAddInServer_Activate(ByVal AddInSiteObject As Inventor.ApplicationAddInSite, ByVal FirstTime As Boolean)
Set oApp = AddInSiteObject.Application
Set oAppEvents = oApp.ApplicationEvents
If frmRegister.CheckRegistration = False Then
Exit Sub
Else
Set oApp = GetObject(, "Inventor.Application")
On Error Resume Next
Dim tf As Boolean
tf = True
For Each oPane In oApp.ActiveEditObject.BrowserPanes
If oPane.Name = "My-Pane" Then
Exit Sub
Next oPane
Set oPane = oApp.ActiveEditObject.BrowserPanes.Add("My-Pane", "MyMenu.MyMNU")
Set MyMenu = oPane.Control
End Sub
Private Sub ApplicationAddInServer_Deactivate()
Set oPane = Nothing
Set MyMenu = Nothing
Set oDoc = Nothing
Set oApp = Nothing
Unload Me
End Sub
Private Property Get ApplicationAddInServer_Automation() As Inventor.AddInAutomation
End Property
Private Sub ApplicationAddInServer_ExecuteCommand(ByVal CommandID As Long)
End Sub
Emil Einarsson
CadCam-it
