BrowserPane Activate method not working
gavbath
gavbath
In Inventor 2019, it appears that the "Activate" method on the BrowserPane object no longer works.
I wonder if this was broken by the change to the new style browser tabs.
Can anyone confirm this is indeed an issue?
If I try to switch from one pane to another, I can see that the ActivePane property changes in the immediate window, but I don't see the change in the UI.
Example code:
ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
chandra.shekar.g
Autodesk Support
Autodesk Support
@gavbath,
Try below code to activate Model Browser pane.
ThisApplication.UserInterfaceManager.DockableWindows.Item("Model").Visible = True
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
JaneFan
HI @gavbath
This is a known issue, and we have get it fixed now but not being included in 2019. Is the work around @chandra.shekar.g provided OK for you?
Jane Fan
Inventor/Fusion QA Engineer
