BrowserFolder How to add a workpoint with vba?
wolfgang_nickl
wolfgang_nickl
When I try to add a Workpointnode to a existing Browserfolder an error occurs.
When I do the same with a part it works.
How can I add a Workpoint to a given Browserfolder.
You can see it with the following example:
1. Open an new assembly
2. Insert a Browserfolder "NewFolder"
3. Insert a Part
4. Insert a Workpoint
5. run the following code
Sub AddtoBrowserFolder()
    ' Ref to AssebmlyDocument
    Dim oAssmDoc As AssemblyDocument
    Set oAssmDoc = ThisApplication.ActiveDocument
    ' Ref to activePane
    Dim oPane As BrowserPane
    Set oPane = oAssmDoc.BrowserPanes.ActivePane
    'Ref to Folder 'NewFolder'
    Dim oFolder As BrowserFolder
    Set oFolder = oPane.TopNode.BrowserFolders("NewFolder")
    'ref to secondlast nod(Part)
    Dim oBrowserNode As BrowserNode
    Set oBrowserNode = oPane.TopNode.BrowserNodes.Item(oPane.TopNode.BrowserNodes.Count - 1)
    Debug.Print oBrowserNode.FullPath
    Call oFolder.Add(oBrowserNode)
    oPane.Refresh
    MsgBox "no error"
    'ref to last node (Workpoint)
    Set oBrowserNode = oPane.TopNode.BrowserNodes.Item(oPane.TopNode.BrowserNodes.Count)
End Sub
What is wrong?
Best Regards
Wolfgang
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @wolfgang_nickl
Try the following approach to add workspoint to browser folder.
    ' Ref to activePane
    Dim oNew As BrowserFolder
    Dim oCol As ObjectCollection
    Set oCol = ThisApplication.TransientObjects.CreateObjectCollection
    oCol.Add oBrowserNode
    Set oNew = oPane.AddBrowserFolder("NewFolder", oCol)
    ' Delete the redundant browser folder
    oFolder.Delete
End Sub
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
wolfgang_nickl
Hello Chandra,
thank you for your solution.
Also 'new folder' is moving down in the browser,
it works for me because in my case position of folder can move.
Best Regards
Wolfgang
