Breaking Drawing View - Very Strange Behavior
aelqabbany
aelqabbany
I have cobbled together a script that will take a large drawing view and break it in multiple places without hiding any important features (including hidden holes or hidden line ends).
The two issues I have are:
  1. It seems that the script avoids hidden holes correctly, but ignores visible holes.
  2. The script seemingly hides some hidden lines correctly, but ignores others.
Starting Position
 Why does it only hide some of the long horizontal hidden lines?
 Good first break
 Good second break
Why did the break override the holes here?
 Final break
The breaks managed to avoid the hidden holes in the middle part, but overran the holes on the right.
Any suggestions? I have attached my sample part.
Sub Main()
	CreateBreakoperationInDrawingView()
End Sub
Public Sub CreateBreakoperationInDrawingView()
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    Dim oDrawingView As DrawingView
    oDrawingView = oDrawDoc.SelectSet.Item(1)
	Dim NumOfBreaks = 0
	Dim oCurves As DrawingCurvesEnumerator = oDrawingView.DrawingCurves
	For Each oC As DrawingCurve In oCurves
	If oC.CurveType = CurveTypeEnum.kLineSegmentCurve Then
	Try
		If EqualWithinTolerance(oC.EndPoint.Y , oC.StartPoint.Y, 0.01)  And oC.Segments(1).HiddenLine = True And Abs(oC.StartPoint.X-oC.EndPoint.X) > 10 Then
		oC.Segments(1).Visible = False
		oC.Segments(2).Visible = False
		oC.Segments(3).Visible = False
		Catch
		End Try
	Next
	While NumOfBreaks < 5 And oDrawingView.Width > 40
		MessageBox.Show("Message", "Title")
    Dim oCenter As Double
    oCenter = oDrawingView.Center.Y
	Dim X_Values = New Double() {}
		Try
			X_Values = X_Values.Concat({oC.StartPoint.X}).ToArray
		Catch
		End Try
		Try
			X_Values = X_Values.Concat({oC.EndPoint.X}).ToArray
		Catch
		End Try
		Try
			If oC.CurveType <> CurveTypeEnum.kLineSegmentCurve Then
				X_Values = X_Values.Concat({oC.MidPoint.X }).ToArray
		Catch
		End Try
	Next
	Array.Sort(X_Values)
	Dim Max_Gap As Double = 0
	Dim Break_End As Point2d
	Dim Break_Start As Point2d
	For i = 0 To (X_Values.Length - 2)
	If (X_Values(i + 1) - X_Values(i)) > Max_Gap Then
		Max_Gap = X_Values(i + 1) -X_Values(i)
		Break_End = ThisApplication.TransientGeometry.CreatePoint2d(X_Values(i + 1) -1,oCenter)
		Break_Start = ThisApplication.TransientGeometry.CreatePoint2d(X_Values(i) +1, oCenter)
	Next
    Dim oBreakOperation As BreakOperation
    oBreakOperation = oDrawingView.BreakOperations.Add(kHorizontalBreakOrientation, Break_Start, Break_End, kStructuralBreakStyle, 5)
	NumOfBreaks += 1
	End While
oDrawingView.Position = ThisApplication.TransientGeometry.CreatePoint2d(20, 22.5)
End Sub
aelqabbany
It seems that for some Line Drawing curves, the first segment can be visible whereas the second segment can be hidden, which is why the prior code was skipping over them.
This code has resolved the issue:
Try
If oC.CurveType = CurveTypeEnum.kLineSegmentCurve And EqualWithinTolerance(oC.EndPoint.Y, oC.StartPoint.Y, 0.01) And Abs(oC.StartPoint.X - oC.EndPoint.X) > 10 Then
		For Each oLineSegment As DrawingCurveSegment In oC.Segments
			If oLineSegment.HiddenLine = True Then
				oLineSegment.Visible = False
		Next
Catch
End Try
Next
aelqabbany
Apparently, the circles that were being overridden were not circles after all, but curves of the type kCircularArcCurve and kEllipticalArcCurve, which don't have a midpoint.
This has resolved the other issue:
		Try
			X_Values = X_Values.Concat({oC.Segments(1).StartPoint.X}).ToArray
		Catch
		End Try
		Try
			X_Values = X_Values.Concat({oC.Segments(1).EndPoint.X}).ToArray
		Catch
		End Try
		Try
		Catch
		End Try
	Next
