Break reuse member in frame generator
DWhiteley
Advisor Advisor
DWhiteley
I wish to trap this function in the frame generator in order to rename the file/part number on the newly created member.
I cannot 'trap' it in the usual way by using FILEUIEVTS_ONPOPULATEFILEMETADATA, is there any other way I can get to this command to rename the new part that is being created?
Many thanks
Dave
adam.nagy
Autodesk Support
Autodesk Support
Hi Dave,
Could you please list the exact steps in the UI that you'd like to automate?
I'm not sure what the Break reuse is. I can see the command reuse - is that what you mean?
Cheers,
Adam Nagy
Autodesk Platform Services
LukeDavenport
Hi Adam - I think he means this command - RMB on a single frame member that has been reused.
Luke
adam.nagy
Autodesk Support
Autodesk Support
Thanks Luke! 🙂
Dave's other post put me on the right track: http://forums.autodesk.com/t5/inventor-customization/frame-generator-command-quot-break-reuse-member...
Adam Nagy
LukeDavenport
Ah yes he's a clever fella that Dave.
Cheers
Luke
