BoundaryPatch from Sketch3D with SketchEntities3D - API C# or VB.NET
florian_wenzel
Message 1 of 1
florian_wenzel
Inventor 2024
API Visual Studio C#
i try to create a Surface with BoundaryPatch using BoundaryPatchFeature.
Is there a way, to Create a Path, GuideRail or Profiles3D ?
So the problem is, that if i Create Curves with API, and i dont Connect the Points, then this is not a Profile3D,
and im not able to Create Profile.AddClosed()
a Surface with BoundaryPatch Feature.
Is there a WorkAround, or any Solution?
I was try with Path,  CreatePath or CreateSpecifiedPath.
Or with only One SketchEntity, with each etc..
How to Use the GuideRail with BoundaryPatch Feature?
Example Code:
        PartDocument oPartDoc = (PartDocument)Globals.g_inventorApplication.ActiveDocument;
            PartComponentDefinition oCompDef = oPartDoc.ComponentDefinition;
            TransientGeometry oTG = Globals.g_inventorApplication.TransientGeometry;
            TransientObjects oTO = Globals.g_inventorApplication.TransientObjects;
            TransientBRep oBRep = Globals.g_inventorApplication.TransientBRep;
            MeasureTools oMeasureTools = Globals.g_inventorApplication.MeasureTools;
            Sketch3D oSketch3D = oCompDef.Sketches3D[1];
            ObjectCollection oObjColl = oTO.CreateObjectCollection();
            foreach (SketchEntity3D oSketchEntity3D in oSketch3D.SketchEntities3D)
                if (oSketchEntity3D.Type != ObjectTypeEnum.kSketchPoint3DObject)
                    //Path oPathGuide = oCompDef.Features.CreatePath(oSketchEntity3D);
                    oObjColl.Add(oSketchEntity3D);
            Path oPathGuide = oCompDef.Features.CreateSpecifiedPath(oObjColl);
            ObjectCollection oObjColl2 = oTO.CreateObjectCollection();
            oObjColl2.Add(oPathGuide);
            BoundaryPatchDefinition oBoudaryPatchDef = oCompDef.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition();
            oBoudaryPatchDef.GuideRails.Add(oObjColl2);
            BoundaryPatchFeature oBoundaryPatch = oCompDef.Features.BoundaryPatchFeatures.Add(oBoudaryPatchDef);
Thanks For any Suggestion
Replies (0)
