BoundaryPatch from Sketch3D with more Loops
florian_wenzel
florian_wenzel
Inventor 2022
VB.NET Visual Studio
i try to make a Face with BoundaryPatch Feature.
I want to use a Sketch3D with few Loops, it works with GUI.
My Question is how to get each loop (Path or Profile)  to reach the Goal?
How to Get info How many Loops in a Sketch3D i have ?
This is my Code: in Progres
    Public Sub CommandFunctionfweButton_34()
        Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
        Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
        Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
        Dim oBRep As TransientBRep = g_inventorApplication.TransientBRep
        Dim oSketch3D As Sketch3D = oCompDef.Sketches3D.Item(1)
        Dim oBoudaryPatchDef As BoundaryPatchDefinition = oCompDef.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
        For i = 1 To oSketch3D.SketchEntities3D.Count
        Next
        Dim oBoudaryPatchLoopOutside As BoundaryPatchLoop = oBoudaryPatchDef.BoundaryPatchLoops.Add()
        Dim oBoudaryPatchLoopInside As BoundaryPatchLoop = oBoudaryPatchDef.BoundaryPatchLoops.Add()
        Dim oBoundaryPatch As BoundaryPatchFeature = oCompDef.Features.BoundaryPatchFeatures.Add(oBoudaryPatchDef)
    End Sub
Thanks for Any Suggestion
florian_wenzel
How to get the Profiles3D?
    Public Sub CommandFunctionfweButton_20()
        Dim oProfiles As List(Of Profile3D) = New List(Of Profile3D)()
        oProfiles.Add(oSketch3D.Profiles3D.AddClosed)
        Dim oProfile As Profile3D = oProfiles.Item(0)
        Dim oBoudaryPatchLoopOutside As BoundaryPatchLoop = oBoudaryPatchDef.BoundaryPatchLoops.Add(oProfile)
        oBoudaryPatchDef.BoundaryPatchLoops.Item(1).SetBoundaryCondition(oProfile, BoundaryPatchConditionEnum.kTangentBoundaryPatchCondition)
    End Sub
I dont understand the Method "oBoudaryPatchDef"
Inventor 2022 Help | BoundaryPatchDefinition Object | Autodesk
florian_wenzel
Hi Autodesk Inventor Developers,
@adam.nagy
@CGBenner
@MjDeck
@AlexKorzun
How to get information, how many loops is in 3D Sketch.
How to do this with API?
Is this, what im asking in my First Post in This Topic possible with API?
adam.nagy
Autodesk Support
Autodesk Support
I always suggest people that they investigate object hierarchy in VBA:
https://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
In case of Sketch3D the Profile3D you create for it will include ProfilePath3Ds
Adam Nagy
Autodesk Platform Services
florian_wenzel
Hi @adam.nagy
sorry, i need stil help.
I was bussy with other things.
Where is the Problem?
ok, the Profiles are ok, and it works with Each Profile separately, but How to get the Surface with Holes?
Do i still need something ?
In this Case, the First Profile is the Outside one.
    Public Sub CommandFunctionfweButton_()
        Dim oProfiles As Profile3D = oSketch3D.Profiles3D.AddClosed()
        Dim oObjCollProfile As ObjectCollection = oTO.CreateObjectCollection
        MsgBox("Profiles = " & oProfiles.Count)
        For i = 1 To oProfiles.Count
            oObjCollProfile.Clear()
            Dim oProfilePath As ProfilePath3D = oProfiles.Item(i)
            MsgBox("ProfilesPath = " & oProfilePath.Count)
            For j = 1 To oProfilePath.Count
                Dim oProfileEntity As ProfileEntity3D = oProfilePath.Item(j)
                Dim oCurve As SketchEntity3D = oProfileEntity.SketchEntity
                oObjCollProfile.Add(oCurve)
            Next
            Call oBoudaryPatchDef.BoundaryPatchLoops.Add(oObjCollProfile)
        Next
    End Sub
adam.nagy
Autodesk Support
Autodesk Support
It's much easier to test things in VBA - that's what I do as well. There you can examine objects as you step through the code. As shown in the picture you can see that the BoundaryPatchDefinition ends up with just a single SketchCircle3D in each BoundaryPatchLoop
This suggests that BoundaryPatchLoops.Add() does not copy the collection you pass in, but simply adds a reference to it. And so, you should create a new collection object for each loop:
    Dim g_inventorApplication As Application
    Set g_inventorApplication = ThisApplication
    Set oPartDoc = g_inventorApplication.ActiveDocument
    Set oCompDef = oPartDoc.ComponentDefinition
    Set oTO = g_inventorApplication.TransientObjects
    Set oTG = g_inventorApplication.TransientGeometry
    Set oBRep = g_inventorApplication.TransientBRep
    Set oSketch3D = oCompDef.Sketches3D.Item(1)
    Set oProfile = oSketch3D.Profiles3D.AddClosed()
    Set oBoudaryPatchDef = oCompDef.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
    For Each oProfilePath In oProfile
        Set oObjCollProfile = oTO.CreateObjectCollection
        For Each oProfileEntity In oProfilePath
            Set oCurve = oProfileEntity.SketchEntity
            Call oObjCollProfile.Add(oCurve)
        Next
    Next
    Set oBoundaryPatch = oCompDef.Features.BoundaryPatchFeatures.Add(oBoudaryPatchDef)
End Sub
This worked:
Adam Nagy
florian_wenzel
Hi @adam.nagy ,
Thanks very Much, the Boundary Feature Works.
ok, got it!
no further investigation
