Boundary patch with guide rails using VBA (API)
Message 1 of 10
Hello everybody.
I have this Surface:
I don't have any problem with the code until this point, but I can not find any example or guide to make a Boundary patch with guide rails. What I want is to get this Surface:
Could anyone help me with this code using boundary patch operation WITH GUIDE RAILS?
I need examples, just to have an idea about how to programm that operation.
Thanks!
PD:
Here you are a Little of my code:
        Dim oBoundaryPatchDef As BoundaryPatchDefinition
        oBoundaryPatchDef = partDef.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
        Dim oProfileLine As SketchLine
        Dim oPath As Path
        For Each oProfileLine In sketchXY.SketchLines
            oPath = partDef.Features.CreatePath(oProfileLine)
            Call oBoundaryPatchDef.BoundaryPatchLoops.Add(oPath)
        Next
        Dim oBoundaryPatch As BoundaryPatchFeature
        oBoundaryPatch = partDef.Features.BoundaryPatchFeatures.Add(oBoundaryPatchDef)
Replies (9)
Message 2 of 10
Xun.Zhang
Hi @YuhanZhang, Could you help shed some lights here?
Thanks!
Xun
Message 3 of 10
YuhanZhang
Seems I could not see your pictures(not sure if others can see them or not), can you create a Word document to demonstrate the problem?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Message 4 of 10
OK, I will check
Message 5 of 10
I had the same problem with Mozilla FireFox browser. I just had to wait some time and then I could watch the pictures. If problem persists, please tell me.
Here I attach the pictures in the order specified in the post.
kelly.young has embedded your images for clarity.
Message 6 of 10
Thanks for your help, by the way 🙂
Message 7 of 10
YuhanZhang
If the second sketch has a sketch arc and control point spline, then you can try below VBA sample:
Sub CreateBPWithGuiderail()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSk1 As PlanarSketch, oSk2 As PlanarSketch
    Set oSk1 = oDoc.ComponentDefinition.Sketches(1)
    Set oSk2 = oDoc.ComponentDefinition.Sketches(2)
    Dim oProfile1 As Profile
    Set oProfile1 = oSk1.Profiles.AddForSurface
    Dim oBPDef1 As BoundaryPatchDefinition
    Dim oBP1 As BoundaryPatchFeature
    Set oBPDef1 = oDoc.ComponentDefinition.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
    oBPDef1.BoundaryPatchLoops.Add oProfile1
    Set oBP1 = oDoc.ComponentDefinition.Features.BoundaryPatchFeatures.Add(oBPDef1)
    Dim oBPDef2 As BoundaryPatchDefinition
    Dim oBP2 As BoundaryPatchFeature
    Dim oGuideRails As ObjectCollection
    Set oBPDef2 = oDoc.ComponentDefinition.Features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
    oBPDef2.BoundaryPatchLoops.Add oBP1.Faces(1).EdgeLoops(1)
    Set oGuideRails = ThisApplication.TransientObjects.CreateObjectCollection
    Set oPath = oDoc.ComponentDefinition.Features.CreatePath(oSk2.SketchControlPointSplines(1))
    oGuideRails.Add oSk2.SketchArcs(1)
    oGuideRails.Add oSk2.SketchControlPointSplines(1)
    oBPDef2.GuideRails = oGuideRails
    Set oBP2 = oDoc.ComponentDefinition.Features.BoundaryPatchFeatures.Add(oBPDef2)
End Sub
Please let me if it works for you.
Rocky Zhang
Inventor API PD
Message 8 of 10
It worked perfect!
Thanks a lot!
You have helped me a lot!
Message 9 of 10
Hello @YuhanZhang may I ask you for help with this?
I want to create boundary patches where these triangles are, to make a B-rep solid out of this 3D sketch via VBA. I don't know what path to give to the boundary patch definition model, for it to create the patches.
I tried this, which didn't work:
Dim oLine3d As SketchLine3D
Dim oPath As Path
For Each oLine3d In oSketch3d.SketchLines3D
oPath = oDef.Features.CreatePath(oLine3d)
Next
Cheers,
Omar
Message 10 of 10
YuhanZhang
Can you provide your data so I can try with it? Don't share confidential data here.
Rocky Zhang
Inventor API PD
