BOM
BOM
GosponZ
BOM
GosponZ
I'm using this code to export bom and it is working good. But here is question. Is it possible to exclude purchased parts from bom?
fileName=ThisDoc.PathAndFileName(False)&".csv"
ThisBOM.Export("Parts Only", fileName&".csv", kTextFileCommaDelimitedFormat)
adam.nagy
Autodesk Support
Autodesk Support
You can either:
a) export all the info yourself by iterating through the BOM
b) export it using Export() and then modify the created csv file
In either case you'd need to iterate through the BOM to find out which items are purchased.
Cheers,
Adam Nagy
Autodesk Platform Services
GosponZ
Hm..
by creating my parts i determne which parts are purchased and those parts i do not need to export in csv file since i'm using them for other purpose later. Just to save me a little bit of time i thought that is possible to add line of code just to exclude purchased parts which has designation in BOM structure .
mslosar
There is an example of iterating through the BOM in the programming help file that comes with inventor.
It's under Samples>Assemblies>Bill of materials>Using the BOM APIs
Least, that's where it is in 2013.
As you loop through you should be able to check for the BOM type of a part
