BOM StructuredViewFirstLevelOnly = False ArgumentException
herrwolf1
herrwolf1
I'm trying to set the BOM Structured options. I get the following error when I try to change the StructuredViewFirstLevelOnly property from both the assembly and drawing environments. All this code came from the help files. Any suggestions?
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Code from the drawing environment.
        ' Set a reference to the referenced model document
        Dim oModelDoc As Document
        oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
        ' First check if the 'structured' BOM view has been enabled in the model
        ' Set a reference to the model's BOM object
        Dim oBOM As BOM
        oBOM = oModelDoc.ComponentDefinition.BOM
        oBOM.StructuredViewFirstLevelOnly = False ' This Line Crashes.
        oBOM.StructuredViewEnabled = True
Jef_E
I am encountering the same error.. any Ideas?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
