BOM Override ilogic snippet
alauth
alauth
Wondering if there is a way to change the ilogic snippet to override the BOM value based on a filename instead of the part number?
Curtis_W
Hi alauth,
This will write the file name to the part number iproperty. The False results in no file extension, set it to True if you want to include the extension.
I hope this helps.
Curtis
iProperties.Value("Project", "Part Number")  =  ThisDoc.FileName(False)
