BOM list main assembly static value
Working with Revit and Inventor we created a specific workflow. We build all detail parts/assemblies in Inventor, for example a column with all bolts and nuts. We than export the assembly to Revit and place the assembly on the grid and array it as much as needed (sometimes up to 8000 times). When in Revit the model with all parts is ready we manipulate the BOM list in the main assembly in Inventor to the quantities needed in the project (quantities from Revit) and we know how much bolts and nuts we need in the total project.
One problem is that on the production drawings in Inventor we need the total quantity of parts and welding’s needed to produce for the complete project. For parts I found a Ilogic rules that will look in the Bom list and copy the amount to an IProperty this works perfect. For weldment’s the program will only count the amount in the Inventor assembly and not the static value in the Bom list.
Question: Is there an option to get the static value from a weldment in the Bom list and export that to an IProperty?
PS: Sorry but I'm not able to find how wrote the program, but if you wrote it than thank you!
'iterate through an assembly and assign a part qty to all parts and sub assemblies
Sub Main
'Rebuild all
ThisDoc.Document.Rebuild()
'Get current document
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
'Get the BOM object
Dim oBOM As BOM = oAssyDef.BOM
'enable the Parts Only View
oBOM.PartsOnlyViewEnabled = True
'Get the Parts Only view of the BOM
Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item("Parts Only")
'declare variable for each BOM row.
Dim oBOMRowPO As BOMRow
'Set the name of the custom iProperty
'Dim oIPropertyName As String = "Authority"
'MessageBox.Show("debug")
'For each row in the Parts Only BOM, do the following
For Each oBOMRowPO In oBOMViewPO.BOMRows
'Set a reference to the primary ComponentDefinition of the row
Dim oCompDef As ComponentDefinition = oBOMRowPO.ComponentDefinitions.Item(1)
'get the full filename associated to the component in the row. ex: c:\temp\part1.ipt
Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
Dim CompFileNameOnly As String
'get the location of the last backslash
Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
'get the filename only from the full filename
CompFileNameOnly = CompFullDocumentName.Substring(index+1)
'MessageBox.Show(CompFileNameOnly)
'get the Qty value in the current row
Dim Qty As String = oBOMRowPO.TotalQuantity
'check to see if the component is a library part, cc part or read only.
Dim IsLibCCReadonly As Boolean = LibCCReadonlyChecker(CompFullDocumentName)
'if the file is NOT a library part, cc part or read only.
If IsLibCCReadonly = False Then
'set following custom iproperty to equal the QTY from the row
iProperties.Value(CompFileNameOnly, "Project", "Authority") = Qty
'set built in iProperty
'iProperties.Value(CompFileNameOnly, "Status", "Mfg. Approved By") = Qty + " RQD"
Next
'At this time, the qty value for all parts have been copied to the custom property.'next, the following code will cycle through only the subassemblies.
'if the Structured BOM view is enabled then...
If oBOM.StructuredViewEnabled Then
'If show First Level is set then turn it off. This will set it to All Levels
If oBOM.StructuredViewFirstLevelOnly Then
oBOM.StructuredViewFirstLevelOnly = False
Else
'enable the Structured BOM view
oBOM.StructuredViewEnabled = True
'set the FirstLevelOnly to false therefore make it All Levels
'Get the Structured view of the BOM
Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item("Structured")
Dim oBOMRowStruc As BOMRow
'Create a blank array(list). This will be used to store a list of all subassemblies for comparing if the subassembly already exist.
Dim arrSubAssemblyList As New ArrayList
'call a subroutine to cycle through the structured BOM. It will need the collection of rows, the subassembly list, and 1 is the initial parentqty.
Call QueryBOMRowProperties(oBOMViewStruc.BOMRows, arrSubAssemblyList, 1)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, arrSubAssembly As ArrayList, oParentQty As Integer)
'declare a incrementer variable
Dim i As Long
'for each row in the structured BOM
For i = 1 To oBOMRows.count
'get the row based on the incrementer
Dim oBOMRowStruc As BOMRow = oBOMRows.item(i)
'get the component definition assocated with the row
Dim oCompDef As ComponentDefinition = oBOMRowStruc.ComponentDefinitions.Item(1)
Dim oQty As Integer
'If the component is an assembly and it's bom structure is Normal then do the following. else do nothing
If TypeOf oCompDef Is AssemblyComponentDefinition And oCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
'get the full filename associated to the component in the row. ex: c:\temp\subassembly.iam
'get the qty of the row and multiply by the parent qty.
oQty = oBOMRowStruc.ItemQuantity* oParentQty
'create a variable that will be used to get the qty of the subassembly if it was used elsewhere
Dim additionalQty As Integer = 0
'if the subassembly list is not empty then...
If arrSubAssembly.Count <> 0 Then
'create a counter. this will be used to determine which item in the subassembly array (list) when it finds a match.
'this counter will be used to edit that item with the new qty.
Dim counter As Integer = 0
'for each item in the subassembly array (list) starting at 0 (first item) to last item
For j As Integer = 0 To arrSubAssembly.Count-1
'get the location of the colon
Dim commaindex As Integer = arrSubAssembly(j).indexof(":")
'get just the file name
Dim CompName As String = arrSubAssembly(j).substring(0,commaindex)
'if the file name of the current row matches the current item in the subassembly array (list) then...
If CompName = CompFileNameOnly Then
'set the additional qty to the qty found in the subassembly array (list)
additionalQty = arrSubAssembly(j).substring(commaindex+1)
'set the counter equal to the item in the subassembly array (list)
counter = j
'since a match is found, we need to exit the for loop so that counter no longer increments.
'so Set j To the number of items in the subassembly array. this will exit out the for loop.
j = arrSubAssembly.Count
Else
'increase the counter
counter += 1
Next
'if additional qty was not changed then there was no match. It will be a new item in the subassembly array (list)
If additionalQty = 0 Then
'add the subassambly to the subassembly array (list)
arrSubAssembly.add(CompFileNameOnly & ":" & oQty)
Else
'if it did find a match, then update the qty for that item in the subassembly array (list)
arrSubAssembly(counter) = CompFileNameOnly & ":" & oQty + additionalQty
Else
'add the first subassembly to the list. It will add the filename and the qty separated by a colon. ex. subassembly.iam:2
'(original code)
'set following custom iproperty to equal the QTY from the row plus the additional qty value
'iProperties.Value(CompFileNameOnly, "Custom", "PartQty") = oQty + additionalQty
'add QTY from the row plus the additional qty value
Dim qtyPlusAdd As String = oQty + additionalQty
'set following iproperty to equal the QTY from the row plus the additional qty value
iProperties.Value(CompFileNameOnly, "Project", "Authority") = qtyPlusAdd
'iProperties.Value(CompFileNameOnly, "Status", "Mfg. Approved By") = qtyPlusAdd + " RQD"
'Recursively iterate child rows if present.
If Not oBOMRowStruc.ChildRows Is Nothing Then
'recall the subroutine, push the childrows of the sub, sub assembly array (list), and the qty of the subassembly
Call QueryBOMRowProperties(oBOMRowStruc.ChildRows, arrSubAssembly, oQty)
Next
End Sub
Private Function LibCCReadonlyChecker(filename As String) As Boolean
' Get the active project
Dim oProject As DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
' Get all the library paths
Dim oLibraryPaths As ProjectPaths = oProject.LibraryPaths
Dim oLibraryPath As ProjectPath
'for each library path in the list of all library paths
For Each oLibraryPath In oLibraryPaths
'get the library path
Dim oLibs As String = oLibraryPath.Path
'if the file is in a library path then Return True
If filename.Contains(oLibs) = True Then
Return True
Next
'if the file is in the CC location then Return True
If filename.Contains(oProject.ContentCenterPath) = True Then
Return True
'get read only status
Dim File_Attr As Long = System.IO.File.GetAttributes(filename)
'if the file is readonly or readonly and archieve then Return True
If File_Attr = 1 Or File_Attr = 33 Then
Return True
'return False if it's not a library, CC or a Readonly part.
Return False
End Function
